stock ls1 boosted
Old Nov 7, 2007 | 04:06 PM
rotacoupe95's Avatar
Default stock ls1 boosted
I wanted to no what is the most people have made on a stock motor with a turbo kit and what kit was used?
Old Nov 7, 2007 | 04:40 PM
HUNTER02SS's Avatar
Not a turbo kit,but a Vortech V9 kit. Made 510rwhp! Lasted over a year before I broke a piston.
Old Nov 7, 2007 | 04:42 PM
jason02Z's Avatar
seep inc made 700 i think then broke after is was on the dyno. im somewhere around 500hp/tq with a t70 on a log manifold
Old Nov 7, 2007 | 05:30 PM
allthrotle's Avatar
Mr. President made like 600 on a turbo setup.
Old Nov 7, 2007 | 06:32 PM
tha joker's Avatar
650 on a maggie setup and still going strong
Old Nov 7, 2007 | 06:58 PM
99Z28LS1's Avatar
ther was a GTO guy with a 76GTS and good cam on an STS setup, he made 620 something before it blew up
Old Nov 7, 2007 | 07:08 PM
BlackMagicC5's Avatar
523rwhp/506rwtq stock LS1 with a Procharger.
Old Nov 7, 2007 | 08:49 PM
vaticano's Avatar
check the sig
Old Nov 7, 2007 | 09:27 PM
PLucas's Avatar
Originally Posted by vaticano
check the sig
Thats impressive
Old Nov 8, 2007 | 10:25 AM
00Z-28Maro's Avatar
507 rwhp/ 573 rwtq SAE on 7psi. Have ran between 7 and 9 psi for a little over a year now.
Old Nov 8, 2007 | 10:36 AM
ssfast99's Avatar
how about stock motor with the exception of a cam. stock 241 heads and ls1 intake with a turbo smaller then a 70mm. i am curious what a 67mm sts kit will do with only a cam upgrade and a tune.
Old Nov 8, 2007 | 05:13 PM
CALL911's Avatar
The problem with running any kind of moderate boost levels on the stock motor is simply that its not reliable. For every 1 or 2 stories of cars holding that kind of boost and power over any period of time, there are dozens more with less boost, and much shorter periods of time that end up doing motor rebuilds because they fried a piston or something else went.
There will always be those who say "my car is still running strong", but the reality is each time you run any kind of decent boost levels on a stock motor, you are rolling the dice. You might make it 25,000 miles, or you might make it 2500 miles.
Old Nov 8, 2007 | 07:31 PM
vaticano's Avatar
thats why the backup plan is already in the garage with forged internals
Old Nov 8, 2007 | 08:12 PM
z28misfit's Avatar
I'd like to turbo my car but like CALL911 said, you never know what really is safe or how long the motor will last and with my current mods who knows how long it will last. Unless you're loaded with $ , buying any FI kit isn't cheap and then if the motor goes only a couple thousand miles later, now what. Spend a few more thousand dollars that aren't even in the finances! We all want more and more power, and getting what you can out of a stock block is kind of the luck of the drawl. You may be successfull and run that setup for awhile or it could be only a few months and then BOOM! But good luck either way.
Old Nov 8, 2007 | 08:18 PM
vaticano's Avatar
i switched to E-85, and i have to say that it really helps with the boom. when i dynoed it it was running at 14:1 afr when it should have been 8.5. the log showed no knock retard whatsoever. it's cheap insurance
Old Nov 8, 2007 | 09:44 PM
Rickys S/C Z28's Avatar
were can we buy E85???
Old Nov 9, 2007 | 07:00 PM
vaticano's Avatar
it would seem that you live in 1 of 9 states that don't sell it
but you could always make your own ethenol and just add the 15% gas to it
