View Poll Results: Which BOV/BPV
Vortech Mondo
5
11.63%
Tial 50mm BOV
7
16.28%
Big Red Procharger
29
67.44%
Other (Please write in response if you choose this one)
2
4.65%
Voters: 43. You may not vote on this poll
Which BOV/BPV for procharger
I'm trying to decide what BOV/BPV to install when I go with my FMIC... Sound is a factor but it's not the biggest one... I rather have a really reliable one versus one that you can hear a mile away... It's okay if you just vote but I really would like testimonies of your experiences...
I think that I'm going to get that one... It's a little expensive but it flows so much more air...
sevinseriesta: I'm already SD tune and I tune myself so it shouldn't be a problem.. They say price reflects quality and just wanted to make sure the Big Procharger one is worth it... If you look at how many cfm it flows there really is no comparison...
They say that with superchargers that you want to go with a bypass instead of a blow off valve... I went ahead and got the procharger cause I eventually gonna go with a 427 LSX block and at least an F1A... It will be plenty for that... Thanks guys for your help..
Just reading here... What are the implications of SD versus MAF applications in regard to the BOV/BPV? Just the location of the device in the tract, right? From what I've read in other posts in this forum, you what the BOV/BPV(in a MAF implementation) to be between the Turbo/SC and the Intercooler to both defeat overheating the Intercooler needlessly with air being discarded and to only discharge un(MAF)metered air. But with SD then, other than the Intercooler aspect, it really doesn't matter where the BOV/BPV is located, right?
That's where I've seen a lot of BPV's placed is in between the blower and intercooler... I know that it really matters with turbos but didn't know that it mattered so much with a supercharger... I'm placing mine where the maf goes... Like I said I'm in SD anyways (don't know if that matters, trying to hear the rule of thumb on this) and it looks more bling that way... =)
On a side note, when you guys go to a FMIC what are you using for a IAT sensor... The one I'm using now is in the plenum and need one I can put in the pipe...
You are correct. A BOV on a Procharger setup sounds like complete ***
I know I had a Tial and hated it. It did its annoying chirp at cruise. The bypass is desgned to vent at cruise and idle and thats what you want. Plus you can use it later down the road with a turbo setup f ya want. If had it for both setup and love it.
Kyle
