Big single turbo + 481ci
F-Bomb did crash, but it was just a scrape and small dent on the side I think. It wasn't a crash, crash. He slid into something. There's a video of it.
Iron 422ci might be the winner for me.
To be installed in the front two corners than?
When will the smaller thumpers be available and what HP can be attained on a 422ci with twins?
I heard single turbos have lag and twins vertually eliminate lag because they are smaller and spin up quicker. If I can have a properly matched single where it'll spin up and eliminate lag and not just hit hard all of a sudden on me, I'd do it. Whatever works and is matched perfectly to my cubic inches. I will build whatever cube engine to fit whatever TT or single T set-up. And I want AT LEAST 1,300 RWHP, 1,500 RWHP would be nice. LSX iron block will be the platform.
Warrior series
454 lsx intercooled twin turbo dual fuel technology intake.
2300hp 2100tq race gas, 1500 hp 1500tq street trim pump gas.
Block: Gm lsx block 9.7 deck
Crankshaft: Callies Magnum 4340 forged 4.250
Connecting rods: Oliver 4340 Billet connecting rods 6.3
Pistons: Je forged pistons, 180 tool steel pins
Rings: Hell fire
Bearings: Clevite engine bearings H series
Valvetrain: Mechanical roller camshaft, 904 size roller lifters, T&D shaft rockers
Cyl Heads: All Pro symmetrical port heads 400+cfm on intakes 6 head bolts per cyl
Induction: Hogan Sheetmetal intake with single mono-blade 1700cfm throttle body. Dual injector per cylinder.
Head Gaskets: SCE Copper gaskets
Fasteners: Arp
Oil System: Billet fabrication aluminum oil pan with hv pump and pick up.
Harmonic Damper: Billet cnc damper
Fuel Management: Electromotive Lap top programmable
Ignition: 60-2 Crank trigger with 4 ignition coils
Exhaust system: Stainless Steel tubular ex headers
Turbochargers: 2 88mm turbonetics tang.
Wastegates: Tial 44 mm v-band billet wastegates
Blow-off valve: Tial
Air to Air intercooler: Custom to your application
Valve Covers: Billet fabrication Sheetmetal Billet rails
Fuel system: Aeromotive fuel pump and filters
I should just use what NRE used on his 1,500 hp 408ci he built for Hot Rod magazine that did the 1,500 mile trip stopping at 5 1/4 mile drag strips along the way 300 miles apart.......with no break downs.
But I gotta keep A/C.
