Stock block + 13psi + 7250rpm = (pics)
Old 11-18-2007, 11:07 PM
XpEdItIoUs's Avatar
So you lost a piston first or spun a bearing first?
It looks like the rod gave up and took the sleeve with it.
Old 11-18-2007, 11:08 PM
frcefed98's Avatar
LSX block time
Old 11-18-2007, 11:22 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
WW!!!!!!! Congratz man!!! Best carnage I've ever seen in this section
If you're gonna go out, may as well go out with a BANG! Seriously dude... good job
You are my new hero.
Old 11-19-2007, 01:12 AM
DanDan's Avatar
Kaboom....Yikes....Good time to upgrade
Old 11-19-2007, 07:10 AM
rufretic's Avatar
Thanks for the props on making it go boom, I think lol. For those of you wondering what happened, I have no idea. I'm pretty good at taking it apart and putting it back together but I am not nearly experienced enough to diagnose. All I see is a mess of broken parts, your guys guess is as good as mine. If I had to guess, I would say it happened because I spun it too high and one of the rod bolts let go.
Old 11-19-2007, 07:38 AM
No Juice's Avatar
Thats impressive!!!
Use some JB Weld, rub some salt in it and GET BACK OUT THERE!!!!
Old 11-19-2007, 08:21 AM
427's Avatar
The crank looks black, that would say the problem was a lack of oil. The stock oiling system is probably what got you......
Kurt
Old 11-19-2007, 08:36 AM
smokinHawk's Avatar
i have spun my engine at 7250 with 15psi, but had forged pistons, rods, ported oil pump, stock crank.
dont think it was the blocks fault
Old 11-19-2007, 08:42 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,207 Likes on 773 Posts
Usually the rods don't break, they will punch a hole in the side of the cylinder before breaking.
rufretic's Avatar
Kurt
The only thing that may throw that idea out is that the engine ran until it quit itself with no oil. It all happened so fast, I'm not sure the order of things but I do know it went at like 7250rpms and all the fluids shot out the hole in the block and out the oil fill in a matter of a second or so then it ran a couple more seconds and then I realized it was no longer running. I didn't think to turn it off until it was too late, I didn't want to crash either and I was going over 130 when it happened. It may be possible it ran a second or so without a drop of oil after the initial damage.
Old 11-19-2007, 08:50 AM
rufretic's Avatar
I didn't mean the rod itself, I meant the bolt holding it. I've read on here that is the weak link for spinning the stock block that high, a lot of people change them for some arp or katech bolts. I was going to but then read the 02s had stronger ones. I guess it really doesn't matter, I needed a stronger block regardless for how hard I'm pushing it.
Old 11-19-2007, 09:32 AM
  #32
Websy21's Avatar
Well congrats on pushing it that far and to a even better new block now
Old 11-19-2007, 09:45 AM
  #33
427
427's Avatar
The crank turned black before the rod dis-connected from heat, that is most likely what caused the rod to fail. If the journal is black, then the culprit is the stock oiling system. The oiling system will not be repaired by changing the engine, something to consider for your next build.
Kurt
Old 11-19-2007, 11:42 AM
  #34
rufretic's Avatar
Kurt
Thanks Kurt. I have another thread going trying to get some advise on block selection if you want to post your thoughts
Old 11-19-2007, 09:32 PM
  #35
67Firebird455's Avatar
Holy hell man, now that is a disaster. What'd that thing sound like coming apart?
Old 11-19-2007, 09:58 PM
  #36
sworaz's Avatar
In case you haven't seen this yet. Here's an lsx block for sale from sponsor.
https://ls1tech.com/forums/lsx-parts-sale/817693-lsx-block-bead-locks-f-s.html
Old 11-19-2007, 10:06 PM
  #37
slmdLS1's Avatar
yikes! thats some serious carnage!
Old 11-19-2007, 10:13 PM
  #38
Shock Hawk's Avatar
I don't know how much power you were making, but I'm sure that you can easily top it if you get with a good engine builder and design an engine for the psi. I don't know if you already did it, but you can at least strengthen your internals up. It would make sense if your connecting rods gave out in tension. I hear that since there's nothing stopping them on the exhaust stroke (no gas to compress), they keep going and stretch a bit permanently. This causes disaster fast.
Old 11-20-2007, 12:46 AM
  #39
Rickys S/C Z28's Avatar
wow man thats crazy!!! i seen the vid and.....WOW but good luck on the build!
Old 11-20-2007, 07:12 AM
  #40
geeteego's Avatar
Been there. I feel for ya.
Make it stronger...good luck!
Quick Reply: Stock block + 13psi + 7250rpm = (pics)
