My first FI
Old Nov 25, 2007 | 11:47 AM
nesikachad's Avatar
Default My first FI
Well, here it is. . .
04 LS1 GTO.
I'm just amazed it fired on the first crank.
fun car.
4lbs of boost right now. I'm 479 to the wheels. A good start right?
Old Nov 25, 2007 | 11:50 AM
mongoose_ss's Avatar
Sweet looking setup. Are you planning to put more boost to it?
Old Nov 25, 2007 | 01:46 PM
fenix999's Avatar
Holy **** where'd you get those gauges in the a-pillar. they look amazing. First time i see that niccce
Old Nov 25, 2007 | 02:01 PM
52172's Avatar
very nice setup bro!!! When are you gonna turn it up? 4lbs you might as well go back to NA.
Old Nov 25, 2007 | 04:03 PM
Hawk108's Avatar
Wow those seem like aweesome #'s for 4 lbs. of boost on an 04.
Old Nov 25, 2007 | 04:08 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's going to be crazy on nitrous and boost. It'll be even more interesting when you crank it up.
Old Nov 25, 2007 | 04:35 PM
2001WS6Vert's Avatar
Those gauges are ****!
Old Nov 25, 2007 | 05:40 PM
venom ws7's Avatar
Beautiful looking setup man keep us posted with some new pics and vids PLZ.
So stock bottom end?????
Old Nov 25, 2007 | 07:13 PM
DeltaT's Avatar
Nice ride. Stunning numbers for 4#. That was with no nitrous, right?
Jim
Old Nov 25, 2007 | 07:31 PM
Reject's Avatar
yeah those guages are awsome! i'm guessing your not going to have much steet duty on that car with that kind of water pump?
Old Nov 25, 2007 | 08:09 PM
PLucas's Avatar
Looking awesome! Sounds like good numbers on 4psi to me
Old Nov 25, 2007 | 08:16 PM
sworaz's Avatar
Looks awesome.
Old Nov 25, 2007 | 09:04 PM
TAEnvy's Avatar
Wow interior looks pimp, only a pillar ive liked from a cosmetic standpoint.
Wow 4psi, sounds like some of them new saleens mustangs, plus like 100 hp, haha
Old Nov 26, 2007 | 12:40 AM
DanDan's Avatar
That interior is insnae...Very nice build. Any plans of upping the boost? Nice work
Old Nov 26, 2007 | 04:26 AM
nesikachad's Avatar
Thanks for the kind words guys.
The short answer on the boost is, I'm not sure.
I really want to, but I've yet to run the motor on the bottle yet. It's a 100 shot set up from HSW.
Worried about the lower half behaving itself since its all stock presently.
South Coast Speed and Sound makes the gauges and A pillars. Owner's name is Abo. Great guy who's real sharp and has an eye for doing stuff right.
Not cheap though. $1900 bucks to do the car that way. (sting!)
Here's the motor in detail in case anyone else gets the itch:
Car:
2004 LS1 GTO w/ Auto 4 spd.
Engine:
Magnuson LS2 112H supercharger, stock ratios.
Lingenfelter CNC ported LS1 cylinder heads. 2.02I/1.57X valves
Comp 921 springs and titanium retainers.
JESEL sportsman 1.7:1 shaft rockers
LS7 lifters
Manley hardened one piece pushrods.
Scooter's Performance Carbon Fiber valve covers
MSD coil packs
MSD wires
TR6 plugs @ .038"
Mezeire electric H2O pump
ATI super dampener (F body model, NOT GTO one)
Kooks 1.875/3.0 headers
Borla Cat back
Lingenfelter GT2-3 camshaft
Kinetics timing chain
I reworked my stock oil pump myself.
Pinned crankshaft
HSW 100 wet shot
HSW stand alone fuel system
GZ Performance Vacuum pump (more on this later)
Snow Performance Meth injection (still in the boxes)
Chassis:
Wilwood Big Brake Kit
Driveshaft shop 1 piece alloy rated to 600hp
Left to do:
Tranny
Pedders/Nol Tec bushings
Widen stock wheels in back
Cowl Hood
TUNES!
Re plumb all the rubber hoses in SS hardline. (bling a ding ding)
The vac pump:
The GZ pump is a great piece. Top quality everywhere.
It also was never meant for a Maggied LS engine. Took a little money and a little creativity, but it will work.
The Maggie comes with a C-5/C-6 (not sure which one) belt tensioner. The pump gets in the way so you must change out to a rigid tensioner. I used a "Speed Inc." one cause Katech told me I was a fool to do this.
(been working fine for last 1600 miles)
The bushings from the Maggie tensioner have to be saved. You need to buy a bolt and washer from Napa or where ever. 10mm X 30mm long 1.5 pitch if memory serves me right.
The upper support bracket gets flipped around and the bushings make up the difference.
Belt is a Gates and measures 104.625 in length. A 104.25 would be better I think.
Was told that Gatorback belts stretch worse than others. This was from the dyno shop that tuned the car.
I had to go to an SD tune for awhile cause at 4lbs I was pegging the stock MAF on cold nights. I now have an LPE MAF good to 1200hp. (so I'm told anyways)
Rocky Mountain Competition Research in Colo Springs did the tune. Mark is a good **** who lives in a black and white world. I liked him immediately.
Not much more to tell I guess.
I'd like to step the boost up to about 9lbs and see what happens. Just hoping I don't have to start ripping the fuel system apart to upgrade it. I've already swapped pumps and I'm not in any hurry to do it again.
Again, thanks for the remarks guys. So far so good.
I'm back in Iraq till this spring, so the car is parked for awhile.
Can't wait for summer!
Here's one last one of the gauges at night. They don't match the OEM light colors, but oh well. Can't have everything I guess.
Old Nov 26, 2007 | 05:02 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Looks good. Especially at only 4 pounds of boost.
Old Nov 26, 2007 | 06:20 AM
2MuchRiceMakesMeSick's Avatar
nice looking setup
Old Nov 26, 2007 | 07:10 AM
nesikachad's Avatar
Actually, with the 160F stat, I have problems getting the motor to make heat.
Meziere pump is 50 gpm regardless of rpm.
I imagine we'll know for sure next summer, but for now it's been great.
We hit some low 80's back home in SD last month, so I was able to see what the car'd do in warm weather.
So far so good.
Old Nov 26, 2007 | 09:08 AM
2002 Trans Am's Avatar
Certainly looks like a lot of fun. Congrats on your 1st FI, looks like you did it right
Old Nov 26, 2007 | 02:26 PM
OWN3D BY MY PROF!
I really like how you integrated the vacuum pump into the blower bracketry. That looks awesome and is rather Macgyverish.
