gotta ask.............
Old Nov 28, 2007 | 01:00 PM
  #41
Quickin's Avatar
Originally Posted by mahhddgtp
Is there a set of twins someone has used on a LSx setup that compares to the numbers the S88 or S91 puts out for the same CI motor?? Beats?
There's a twin turbo 427ci LSX iron blocked engine that makes 1,800 crank horsepower. Just finished it and dynoed it. It has the dual fuel intake that uses a stand alone tank with race gas so the car can be driven all the time on 91 pump gas. Got an email from the shop yesterday that did it.
What was that shops name, hmmmmmmm, can't quite remember..........REN or was it ENR or was it NER....damn, can't remember
Things just keep getting better and better.......
  #42
DrTurbo's Avatar
LS1TECH Sponsor
Indeed.
We are working with a customer on that as well. Our new FI66's using ETT wheels will be a nice setup and the customer is hoping for over 1600hp and quick spool.
Old Nov 28, 2007 | 01:49 PM
  #43
DrTurbo's Avatar
LS1TECH Sponsor
Ok for all of you that have hammered our phones this morning for the size of a GT55...here it is below.....lol. I knew we had a diag. of it on the server, but took a bit to find it.
Old Nov 28, 2007 | 02:19 PM
  #44
1INSANEGTO's Avatar
So.
Length
181.78 + 126.58 MM = 308.36 MM
308.36 X 0.03937 = 12.1401332 Inches.
Tall
124.70 +107.95= 232.65 MM
232.65MM x .03937 = 9.1594305 Inches
Old Nov 28, 2007 | 02:22 PM
  #45
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by 1INSANEGTO
So.
So its safe to say this is about 12.15-12.20 inchs tall
Correcto...
Old Nov 28, 2007 | 02:25 PM
  #46
1INSANEGTO's Avatar
Damn thats big. Pulled out my ol ruler...lol
Old Nov 28, 2007 | 04:47 PM
  #47
mahhddgtp's Avatar
Another plug.... I'm well aware of NRE, but I wanted to know the sizes of the turbos I'd have to be messing with.
Old Nov 28, 2007 | 04:52 PM
  #48
Quickin's Avatar
I just answered your question exactly.
Old Nov 28, 2007 | 05:08 PM
  #49
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
So you are not using NRE, and you are going to use someone else? And you are going to order an OFI kit?
Old Nov 28, 2007 | 05:11 PM
  #50
mahhddgtp's Avatar
404: Turbo sizes not found
"There's a twin turbo 427ci LSX iron blocked engine that makes 1,800 crank horsepower" =! Turbo sizes
Old Nov 28, 2007 | 06:09 PM
  #51
509TURBOFIREHAWK's Avatar
Me personally, I not really impressed with the stuff NRE builds. First of all I notice alot of the parts he uses are not the top of the line. Im not saying there not good, just not the very best. For $50K or $60K that SOB better have billet this Billet that, Alum blocks. If you bought all the stuff he has in them motors and add it up, you wont get to half what he charges.
By the way, and what he's chargin for headers is insane too. Ive bought the same materials he uses, and more of it. and it didnt come to 1/2 what he charges.
Old Nov 28, 2007 | 07:04 PM
  #52
Quickin's Avatar
Maybe you can point out the junk parts for us. And does it mention Billet enough for ya?
Warrior series
454 lsx intercooled twin turbo dual fuel technology intake.
2300hp 2100tq race gas, 1500 hp 1500tq street trim pump gas.
Block: Gm lsx block 9.7 deck
Crankshaft: Callies Magnum 4340 forged 4.250
Connecting rods: Oliver 4340 Billet connecting rods 6.3
Pistons: Je forged pistons, 180 tool steel pins
Rings: Hell fire
Bearings: Clevite engine bearings H series
Valvetrain: Mechanical roller camshaft, 904 size roller lifters, T&D shaft rockers
Cyl Heads: All Pro symmetrical port heads 400+cfm on intakes 6 head bolts per cyl
Induction: Hogan Sheetmetal intake with single mono-blade 1700cfm throttle body. Dual injector per cylinder
Head Gaskets: SCE Copper gaskets
Fasteners: Arp
Oil System: Billet fabrication aluminum oil pan with hv pump and pick up.
Harmonic Damper: Billet cnc damper
Fuel Management: Electromotive Lap top programmable
Ignition: 60-2 Crank trigger with 4 ignition coils
Exhaust system: Stainless Steel tubular ex headers
Turbochargers: 2 88mm turbonetics tang.
Wastegates: Tial 44 mm v-band billet wastegates
Blow-off valve: Tial
Air to Air intercooler: Custom to your application
Valve Covers: Billet fabrication Sheetmetal Billet rails
Fuel system: Aeromotive fuel pump and filters
Old Nov 28, 2007 | 08:18 PM
  #53
I never said ANY of the parts he uses are JUNK. However I can see several parts that to me seem a little suspect for the money.
And am merely pointing out the fact the same or better can be built for ALOT less than what he charges!!!
I can build two of these for what he charges for one of his. http://rides.webshots.com/photo/2375...dy?vhost=rides
By the way, dont get so uptite! Its just one persons opinion.
Also, whats he has in the LSX stuff to me is better than whats in his other motors.
Old Nov 28, 2007 | 08:30 PM
  #54
Quickin's Avatar
People are also paying for his name, which he has proven to be a top turbo builder, maybe the best.
Look at the prices for LPE stuff, double what NRE charges for a fraction of the power, just as another example of how some shops charge hilarious prices for things.
I think he did like 130 dyno pulls with his 408ci TT (1,500 hp) engine, tore it down and it looked like it had never run. So he does build rock solid stuff.
Old Nov 28, 2007 | 08:47 PM
  #55
Your right people are Paying for the name. I believe Kenny Duttwieler is doing LSX stuff too.
Basically my point was Way too much money.
If you have a good builder. Use him and use the best parts you can, in the long run you'll be happy.
Old Nov 28, 2007 | 09:01 PM
  #56
bigturboz28's Avatar
Default Turbo vs. Engine Size vs. HP Goals
To answer the original question, here is something turbonetics published as a guideline....
http://turboneticsinc.com/downloads/...urboMatrix.pdf
Old Nov 28, 2007 | 09:49 PM
  #57
MECHAM's Avatar
Originally Posted by DrTurbo
Phone is ringing off the damn hook.
I thought the holidays would slow things down?? ...................guess I got owned.
let the phone ring...
dont you have turbos to assemble and ship out
Old Nov 28, 2007 | 11:21 PM
  #58
Quickin's Avatar
Probably a dumb question...but.....
Can the down-pipe be opened while doing a run like an N/A engine does with open headers....for more power?
If so, can a cut-out be used?
Old Nov 28, 2007 | 11:35 PM
  #59
tt427ls1's Avatar
LS1TECH Sponsor
No, I woundnt open up the DP, but you can put a cutout on there if you would like. I can install one at the time I make the DP if you decide to order one. Depending what your setup will be you will have a change in boost pressure with the cut out open I would imagine.
Thanks Joel
Old Nov 28, 2007 | 11:58 PM
  #60
Quickin's Avatar
Thanks Joel
Was it you that I spoke with yesterday about the 101mm turbo fitting with your single kit?
So, you're saying you wouldn't open it up but you would put a cut-out on it so I can open it up?????????? What do you mean?
I have it on my things-to-do-list for tomorrow...to call you and ask about what cubic inches my builder should do with my LSX for this set-up. He told me to ask you. If you want to tell me here....what would you use for ci and the S91? I planned to use a sheet metal intake. What heads and cam would you recommend?
Or I'll call ya tomorrow.
Thanks.
