pushing coolant into overflow?
Old Dec 6, 2007 | 09:35 AM
ls2 bait's Avatar
Default pushing coolant into overflow?
anyone had problems with their cars pusching coolant into the overflow under boost but not bringing it back into the radiator?
Old Dec 6, 2007 | 10:59 AM
koolrayz's Avatar
You're lifting the heads, Probably have a head gasket issue now. I would guess you have a tuning issue that is the root cause.
Old Dec 6, 2007 | 11:02 AM
JAvenger007's Avatar
Had same issue. It was the tuning. First see about inspecting the heads/gaskets if they lifted severely or not. Then try adjusting timing and then make sure it isn't running lean under boost.
I went to GM MLS gaskets and LQ9 heads and haven't looked back.
Old Dec 6, 2007 | 11:34 AM
lmt0705's Avatar
head gaskets, been there done that
Old Dec 6, 2007 | 12:43 PM
HUNTER02SS's Avatar
It's not a real big deal. Pushing water is part of the game. Not sure how much hp and spray you are using,but it usually dosn't happen until around the 700hp mark and above.Install new gm mls gasket's and torque them down to 80ft. lbs. as long as you have arp head studs.Check your tune also. Detonation will make you push water prematurly along with to much timing,and bad gas also.
Old Dec 6, 2007 | 08:37 PM
ls2 bait's Avatar
im going to pull a couple more degrees of timing then. its at 24* right now on a 150 wet kit. only making a tad north of 600rwhp. cometic gaskets and arp bolts. not studs. i know this is the forced induction forum but i always hear about u guys pushing water and wanted some more opinions.
Old Dec 6, 2007 | 08:48 PM
DuronClocker's Avatar
Yeah pull a few degrees. 24* sounds like quite a bit with a Torquer V2 (and I imagine your heads are ~62-64cc for a CR around 11?) and 150-shot.
Old Dec 6, 2007 | 09:02 PM
1fstTA's Avatar
head gaskets. continued to have the same problem finally pulled the motor out and bought a lsx block and going that route 6 bolt setup hopefully that solves it.
Old Dec 6, 2007 | 09:06 PM
HUNTER02SS's Avatar
With 600rwhp,I wouldn't think you would be pushing water.?
Old Dec 6, 2007 | 09:26 PM
lmt0705's Avatar
I did it at 470 on my stock motor due to a horrible tune by a former sponsor here (J&J **** SHOP)
Old Dec 6, 2007 | 09:35 PM
Slowhawk's Avatar
LS1Tech Sponsor
You would if the timing is wrong. Bringing the timing down probly won't help much now till the gaskets are changed.I'm sure they probly have tracks in them now.
Old Dec 6, 2007 | 11:10 PM
ls2 bait's Avatar
heads are milled to 60cc and a .040 cometic gasket. so is this gasket trash now? they say they are reusable? it doesnt do a lick on motor. i can beat it all day everyday and not a drop moves til i hit that button. scr is 11.5 and dcr is 8.5ish.
Old Dec 6, 2007 | 11:12 PM
ls2 bait's Avatar
it also didnt do it right away. when i first finished the setup it ran fine for 3 bottles now its done it the last 3 bottles. if i let the car competly cool it will suck it back in to the radiator.
Old Dec 6, 2007 | 11:58 PM
Inspector12's Avatar
TT-TECH Veteran
Couple pieces of advice to offer take them for what they are though. The bolts don't tq as good or evenly as a stud so I would change, and another thing is once you have lifted it will do it easier from then on. you can re-tq your bolts it could and probably will help, but if it were me I'd change to studs MLS or if your gaskest look good you can reuse them since cometic are a tad pricey, but I use the GM MLS's for about $38 a piece so I usually just replace them. Then after a couple of heat cycles re-tq and I bet you won't have any issues especially at those power levels. Good luck. I believe your problem came from the bolts they are just not as effective in even clamping and partly tunning, but if you are using race fuel then more so on the bolts etc...
Old Dec 7, 2007 | 12:18 AM
Yeah, the pretty strong DCR is what I was hinting at by mentioning the SCR and that cam. Great for N/A use, and great for N2O, but you really should back some timing off on the bottle at those power levels with that kind of DCR.
Pull the heads, check the gasket. Ideally replace the bolts with studs, but you should be fine keeping the bolts after you pull some timing. I'd say start with pulling 4* and see how it reacts. Chances are you won't lose a ton of power and you won't push a drop. You can add back a degree or two if you want, but I bet it won't be THAT noticeable when spraying to make it worth it if you're a street car N/A though...we pulled 4* out from 5000RPM+ on my car, and I lost 2-3mph in the 1/4 NA.
Old Dec 7, 2007 | 12:34 AM
waterbug1999's Avatar
Mine does the exact same thing as you described to the tooth.. I am at 24* as well with my 100 shot.
It did not start losing water till ~8 bottles later and on N/A, doesnt lose a drop. I have .040" cometic and miled 59cc dart heads.
I was palnning on pulling the heads off come spring as its too damn cold in th garage during the winter.
Old Dec 7, 2007 | 10:15 AM
koolrayz's Avatar
If your running pump gas and 24* of timing I definatly think thats what caused the issue. Pushing no water on motor and a little on the bottle is common. Once they lifted they wont stop (this is all something I have experienced not hearsay) I actualy saw more MPH after I pulled a little timing after I had a lifting issue (just like yours) from running to much timing. I would DEFINATLY buy new gaskets and the head studs would also be a good idea.
Old Dec 7, 2007 | 02:28 PM
I run 100 octane... But, it prolly started leaking when I was running 92 though.
