How to keep oil from coming out breathers
https://ls1tech.com/forums/sponsor-group-purchases/734396-group-buy-billet-3-catch-can-check-out.html
cause those dont allow for running a catch can to hold that oil that is dripping
on the stock valve covers there is are nipples
you could probably tap your covers so u can run lines to a catch can.
There not a sponsor but a cheap *** part like this I dont see a problem with posting a link. I got mine from the local parts store that carries motorcraft. Took my drilled and tapped oil caps,Grinded the inside a little and shoved these bad boys in. They work rather well!
Ok thats enuff of my PCV secrets for today.
u
Yeah I've seen people put Steel wool into breathers before for a simular effect. Just didn't like it much.
http://www.exoticperformanceplus.com...html?item=1356
We installed this breather on my Z28, hooking it up by way of the valley pan. So far it looks like it is doing the job quite well. Bob
http://www.petsmart.com/product/inde...ductId=2754076
Ron
