1005 rwhp 03 C5...
Old Dec 16, 2007 | 09:18 PM
Andy02Z's Avatar
Originally Posted by nick y
LS7 with brian tooley trick flows w/inconel valves eagle crank manley rods studs, cam motion, je pistons..... BUILT BY CF-PERFORMANCE.COM!!!
Maby the turbos are done? Speed Inc. has made 1150rwhp through a 6 speed on a 402 1000 on a 427 through a 4l80 sounds about where it should be. I am no expert so correct me if im wrong.
Old Dec 16, 2007 | 09:21 PM
2MuchRiceMakesMeSick's Avatar
Wow looks great nick.
Im not sure whats holding you up but the passengers side fuel rail had to be welded/modified so the return fitting wont hit the alternator? I guess im going to have to do this as well.
Old Dec 16, 2007 | 10:07 PM
nick y's Avatar
U MEAN THAT TURBOS ARE THE PROBLEM??ah no.....
i believe it to be a spark issue....
i made 1005 @ 5500 so its got another 60 to 120 in it easy at 19.5 psi if i can figure the issue out...look at the line...at 21psi it was making 80 more threwout until it shut off @ 5250. these turbos produced 40 more hp for every lb at the high psi level!
yeah machine the end off and weld in bung. do the same on the rear of the drover side
Old Dec 16, 2007 | 10:45 PM
onfire's Avatar
Coal Mining Director
I'd pop in a new crank sensor and cam sensor since they are easy to get to.
What size fuel injectors? Converter box? Could be a problem.
Old Dec 16, 2007 | 10:59 PM
nick y's Avatar
96 harlan's
i am thinking cranks sensor as the block wasnt fully machined and that hole wasnt bored, running a small shim under the sensor...ill chech clearances again
Old Dec 17, 2007 | 01:43 AM
chuntington101's Avatar
OMG nick! big thumbs upto you mate! glad its all come together for you.
i wonder what the TTI guys have to say about it??
Chris.
Old Dec 17, 2007 | 02:45 AM
LS2Camaro's Avatar
It does look like your AFR drops off, but that could be due to when the other problem happens, what kind of pump you running? Either way killer setup man, nice numbers.
Old Dec 17, 2007 | 08:55 AM
ScreaminRedZ's Avatar
registered user
Very clean car! Good luck getting it sorted out.
Old Dec 17, 2007 | 09:03 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Talk about bad ***, its just such a nice round # that rolls off the tongue, One Thousand..... mmhmm congratz
Old Dec 17, 2007 | 09:24 AM
nick y's Avatar
Chris.
hey chris
hahaha TTI.....
ah.....thats the alky kit.....
Old Dec 17, 2007 | 09:38 AM
hellbents10's Avatar
LS1Tech Sponsor
You could be on track with the etc problem. I fought this making big power on these cars and running speed density.
Old Dec 17, 2007 | 09:39 AM
  #32
onfire's Avatar
What happens when you turn the boost controller off and just run on the gates? How low is gate boost? Can you get a clean run to the rev limiter on the street on gate boost?
Old Dec 17, 2007 | 10:14 AM
  #33
DrTurbo's Avatar
LS1TECH Sponsor
Nick glad Jose could set you up with the right turbos. They certainly have more room to go.
Old Dec 17, 2007 | 10:19 AM
  #34
JS's Avatar
JS
Time for Dales tuning and a BSIII
Old Dec 17, 2007 | 02:43 PM
  #35
Kaneman's Avatar
So my car is doing the same thing right at 5200-5500. Did you end up finding a solution?
What spark plug do you run?
Kane
Old Dec 17, 2007 | 05:22 PM
  #36
nick y's Avatar
Kane
not yet..
TR6
hey if i am to buy truck coilswhich ones and any part #s???'
thanks!
Old Dec 17, 2007 | 05:30 PM
  #37
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You may be running into a few issues. One may be backpressure. You said this run was at 21psi and you made less power compared to the 19psi run. You may also be running out of injectors. Let us know what the rest of your fuel setup entails.
Old Dec 17, 2007 | 06:12 PM
  #38
Inspector12's Avatar
TT-TECH Veteran
Well a few suggestions to try nothing big, but I would switch to a little colder plug like a BP7EFS NGK-3526 Heat range 7 or even an 8. I wasn't having a missing issue, but I was having Valve float so I was wondering what springs you are running and what cam lobes. The ones TEA sent me with my TFS heads werent enough even though they were there upgraded spring think it was or is a cam or valve train issue lots have had that issue whith your HP range FYI.You can use the truck coils, but don't think it is your issue as LS1's are fine as long as they are all working properly and as long as they are not exposed to exessive heat because of location. Over all looks like a very nice setup hope that A4 holds for you. I believe Tom (onfire) and David(MM) are probably off in the area of your problem, David had that issue for a while don't remember what the fix was though so I know he is shooting from experience.
Jeff
Old Dec 17, 2007 | 07:48 PM
  #39
TAQuickness's Avatar
maybe I missed it, but what your plug gap set to?
Old Dec 17, 2007 | 10:23 PM
  #40
nick y's Avatar
well injectors are ok....96'ers
well when i run only 7.5 psi its kickin but at a higher rpm....6100...the rev limiter is set at 6800 so i cannot see backpressure cause at that low of psi...
please remember that i relocated mt coils and wire are 3 feet long!!!
as i turn up the boost the car cuts out at a lower rpm...ect....
7.5psi = 6100
12psi = 5800
19psi = 5500
21psi =5250
Jeff
this week i will drain oil and pull plug to read....ill replace w/iridiam...thats what those are? plus cooler...dont wanna mess as it runs dead nutz on the street...just cruising i see 15mpg!!!
.34
