Boost Question
Old Jul 2, 2003 | 01:08 PM
Pewter'00Z28's Avatar
Default Boost Question
How much boost do most of you blower guys run with stock compression? 10:5 to 1?
Old Jul 2, 2003 | 01:09 PM
BIGBOS's Avatar
Default Re: Boost Question
well with 10.6:1 compression and 6psi on a procharger I popped a head gasket, I then went to 9.5:1 compression and 4psi and ran fine, but with less power...
High compression and boost =
Old Jul 2, 2003 | 02:39 PM
CHRISPY's Avatar
If you run racegas (104 unleaded) full time and have a good intercooler or water/alky system you "should" be ok with 8-10#s boost on a stock compression motor. Set it up a little FAT on the dyno and use fairly conservative advance.
Cheers,
Chris
Old Jul 2, 2003 | 11:36 PM
phenyxTA's Avatar
With 4#'s and stock compression I went from 390rwhp-470rwhp. I haven't dynoed it yet with 6#'s but the motors still in one piece. (knock on wood)
Old Jul 3, 2003 | 01:33 AM
Heres my thing, I'm buying this motor from this guy in Cali. Its an A.R.E 382 forged, and he has a Vortech blower on it pushing 6 lbs right now. On 91 he put down 681rwhp and I wanted to see if there is more room for power?
Old Jul 3, 2003 | 01:39 AM
BIGBOS's Avatar
Whats the compression on the motor...???
Old Jul 3, 2003 | 03:50 AM
It still has stock compression 10:5 to 1, he wanted to keep it streetable.
Old Jul 3, 2003 | 08:20 AM
Crunch's Avatar
Stock compression on an LS1 F-Body is 10.1:1. If he has 10.5:1, then he had his heads milled for 4 more points. He'd better be careful with adding boost. I probably wouldn't go over 6PSI on pump gas.
