ATI Procharger users
Old Jan 27, 2008 | 11:13 PM
Rickys S/C Z28's Avatar
Originally Posted by kwiksilverz28
407hp/406tq with 5#, stock cam, and a nice safe/conservative tune. Just repullied for 6-7#, and swapped to TR's blower cam. Awaiting tune on 2.24.08 I am done modding this bottom end/stock heads. Hopefully I see 450+hp....
what size pully did you get and were? i have e 3.40 head unit pulley and im only seeing 4 psi and id like to see 7 psi
Old Jan 27, 2008 | 11:22 PM
badass99ss's Avatar
Originally Posted by SCREAMIN01SS
Is the "trap door" method included in EPP's instructions or is that your own way? Any pics or further explination would help. Thanks!!!!!!!!!!
Here ya go...Im making a door to cover the hole
Attached Thumbnails ATI Procharger users-trap-door.jpg   ATI Procharger users-trap-door-2.jpg
Old Jan 27, 2008 | 11:26 PM
badass99ss's Avatar
And the fuel pump/bucket
Attached Thumbnails ATI Procharger users-fuel-bucket.jpg   ATI Procharger users-fuel-bucket-2.jpg
Old Jan 27, 2008 | 11:33 PM
badass99ss's Avatar
This was the most difficult task in my opinion, I cut the hole in the deck (Trap door) to get access to the pump. When I'm done I will make a cover for it. The fuel pump bucket had to be modified so the pump would remain in the fuel, that's the reason for the hole in the side. The Walbro pump does not have a line to pump fuel in to the bucket like the original. Had to modify the bottom so the pump would protrude far enough for the new sock. Use this, it helped me alot(URL in First post).
https://ls1tech.com/forums/fueling-injection/599049-walbro-pump-install-information-here.html
Old Jan 28, 2008 | 12:55 AM
BOONE's Avatar
If you dont want a hole in your floor you can just remove the tank from under the car out the rear. You do not have to remove the rearend and it dont take very long at all. I like a clean floor that is not chopped.
Old Jan 28, 2008 | 01:37 AM
NASTY98TA's Avatar
Default Computer tuned
Has anyone installed the ATI procharger with 8psi of boost from Exotic Performance Plus, and if so- did anyone have their computer turned by them. Any feedback appreciated.
I had my car tuned By these guys and they are the most stand up shop out there, and they do excellent work. They know ATI prochargers like no other.
I will be bringing more work their way in the future.
Brian
Old Jan 28, 2008 | 05:40 AM
EPP's Avatar
EPP
Thumbs up
Brian
Thanks Brian, we appreciate it! Bob
Old Jan 28, 2008 | 06:26 AM
kwiksilverz28's Avatar
This is a P1SC setup with ATI's dual IC's. 6 rib set up. Sea level in FL. Saw 3psi with 4.10 pulley, 5.1psi with 3.7, and have gone to a 3.4. I have yet to test it. I have a dyno session on 2.24.08 and I will post up after that. I have a guage with memory and the tuner can log it off the vaccum too, so will be for sure #'s...
Old Jan 29, 2008 | 05:06 AM
EPP's Avatar
EPP
Thumbs up
Originally Posted by Spade
I had my whole system installed by them about 4 years ago and have nothing but good things to say about them. I even made a trip there last year to do more business with them, stand up people.
Luckily we had to use my clutch pedal assembly on your car, going to a Powerglide was one of the better things I have done.
We were selling off so many parts off of my car I didn't think it would ever seen a track again. Bob
Old Jan 29, 2008 | 05:09 AM
EPP's Avatar
EPP
Thumbs up
Is the "trap door" method included in EPP's instructions or is that your own way? Any pics or further explaination would help. Thanks!!!!!!!!!!
We don't use the trap door method. There isn't anything wrong with making the trap door, but it doesn't take much time to drop the fuel tank from the car. Bob
Old Jan 29, 2008 | 05:10 AM
EPP's Avatar
EPP
Thumbs up
Originally Posted by helicoil
Where can I get a copy of these?
Pm Jake@epp for the instructions. Thanks. Bob
Old Jan 29, 2008 | 09:12 PM
  #32
9t8z28's Avatar
I have the P1SC system from Bob. The tune he loaded was off, but there a ton of factors, and I have learned more as I go along. It took 4 pulls with adjustments on the dyno to get it right. I just swapped cams and upped the boost, so we'll see how long it takes my guy this time.
Install is a breeze if you have any experience. Instructions are a piece of cake. My only regret is not upgrading to the D1SC when I had the chance for $200. Do it. Just pulley it down to where you want. 7 is my goal right now for longevity with the stock bottom end. Eventually I will replace it, upgrade to D1SC, and then crank it up.
I am getting a P-1SC soon. I get told all of the time that I should get the
D-1SC over the P-1SC. I am completely stock and do not intend to boost over 8 p.s.i.
Why should I go with the D-1SC?
Old Jan 29, 2008 | 09:16 PM
  #33
CALL911's Avatar
Because boost is addictive, and most people started out like you only wanting 8#'s or less, but then once they had it for a while, like a hint of cocaine to an addict, they wanted more, and chances are, so will you. The D1SC is capable of the low boost like the P1SC, but then can be pullied to the much higher boost levels, and it only costs a little more than the P1SC, so it just makes since to get one now, instead of going through the hassle of doing it later.
Old Jan 29, 2008 | 09:24 PM
  #34
9t8z28's Avatar
That is exactly what I am always told. I am not going any further with this mode. I want to get it to a certain point, then I have other project cars to attack. But, my question always is:
is the D-1SC gonna be better than the P-1SC at 8 p.s.i. ?
Old Jan 29, 2008 | 10:03 PM
  #35
Spade's Avatar
It went to a good cause that is for sure.
Old Jan 29, 2008 | 10:12 PM
  #36
The D1SC is bigger. It is $200. Just do it. I am dowm to .4" from the smallest size normally available pulley. I am hoping for 6-7psi. The D1SC will not have to work as hard.
It is the one regret I have in my setup so far. Get it and pulley for your goal.
Old Jan 29, 2008 | 10:24 PM
  #37
allthrotle's Avatar
Yes.
Old Jan 30, 2008 | 07:20 AM
  #38
CALL911's Avatar
Originally Posted by allthrotle
Yes.
Agreed. However if its just a power setting or abuse level on the stock motor, you can always pulley it down. The whole idea is with the D1SC its barely going to be trying to put out 8#'s, where as the P1SC is going to be working pretty hard. Besides the option of being able to run 15+#'s of boost later, it will be less wear on the blower with the D1SC than the P1SC.
Old Jan 30, 2008 | 11:05 AM
  #39
great!! thanks and ill be watchin g to see what you got!
Old Jan 30, 2008 | 03:04 PM
  #40
9t8z28's Avatar
So, say I want to run at 8 p.s.i., are the smaller pulleys going to come with the f-body D-1SC kit or am I going to have to spend more money to purchase them also?
