LT4 valve springs with FI?
Old Feb 2, 2008 | 08:43 PM
94blownz281's Avatar
Default LT4 valve springs with FI?
i know a guy that has a T-trim with 16lbs of boost and has a LT4 hotcam kit on the car. not sure how many miles he has had it on his car. but would these springs last? i'm looking at 10-12 psi and need to upgrade my comp ex 612 springs as i don't think they are going to last with boost that high.
what are on options on a LT1 (i'm also running a hotcam cause i got a awesome deal on it.)
i saw some comp springs for $100.00 that are dual springs.
Old Feb 2, 2008 | 10:06 PM
deuce4935's Avatar
Why not go with a Comp Cams beehive spring, or check out lingenfelter performance for they're dual springs.
Old Feb 2, 2008 | 10:14 PM
I didn't think the beehives would be strong enough?
Old Feb 3, 2008 | 08:09 AM
bump
Old Feb 3, 2008 | 07:26 PM
DeltaT's Avatar
Call Comp and tell them what you are planning. For FI, all you really need is a bump of about 40lbs in spring seat pressure.
Jim
Old Feb 3, 2008 | 07:43 PM
yeah thing is they stopped making them cause they had alot of failures in general.
Old Feb 3, 2008 | 11:44 PM
skinnies's Avatar
I used the lt4 valve springs on my setup in my sig, but I also had a stock cam. I wouldn't use them with an aftermarket cam at all and boost.
Old Feb 4, 2008 | 02:14 PM
Cheatin' Chad's Avatar
Stock valve size?
Old Feb 4, 2008 | 02:27 PM
yes stock valves
