Help with ST80 dimensions
Old Feb 5, 2008 | 09:30 PM
engineermike's Avatar
Default Help with ST80 dimensions
Guys, I'm considering swapping out my trusty ole' T76GTS for an ST80, but I'm concerned about fitment. I have 2 questions:
1. What is the outside diameter of the exhaust housing? If possible, how does this compare to the 76GTS?
2. What size is the v-band clamp on the turbine outlet? I've heard 3.5" and also 4".
Thanks!
Mike
Old Feb 5, 2008 | 10:33 PM
ninetres's Avatar
Thanks!
Mike
What size ex housing? The v-band clamp is 3.5" but you need to get it from them as a standard v-band will not work. I learned the hard way.
Old Feb 6, 2008 | 06:05 AM
1.1 AR
Old Feb 6, 2008 | 08:54 AM
DrTurbo's Avatar
LS1TECH Sponsor
We offer them in standard V-bands now as well.
Old Feb 6, 2008 | 02:08 PM
Dr Turbo, do you know the approximate OD of the 1.1 turbine housing? What about the 1.0?
Thanks,
Mike
Old Feb 11, 2008 | 05:04 PM
Anybody? I know there are at least 2 guys out there with a T76GTS and an ST80.
Old Feb 11, 2008 | 06:10 PM
Zombie's Avatar
I've been trying to get a confirmation on the std comp housing discharge size but no one has answered. I thought I heard someone say it was 4".
I'll hopefully have mine in the next week, if no one has answered you by then I can get you some dimentions.
Old Feb 11, 2008 | 08:00 PM
ninetres's Avatar
The thing is the discharge has a really thick flange. I think I got a 3.5"x3" silicone reducer to use for attaching it to my cold piping.
Old Feb 11, 2008 | 11:12 PM
MECHAM's Avatar
discharge is 3.0-3.5" but like nintres said it is really thick and longer than normal ones i have seen.
intake 5"
Old Feb 11, 2008 | 11:22 PM
SS4Matt's Avatar
the V-band is 4". i put my ST80 exhaust housing in the mill and cut down half of that flange that was on it, so it then became a normal V band and i have a 4" downpipe strait off the turbo!
the discharge on the outlet of the compressor is 3 1/2" but it has this retardedly HUGE collar around it so it takes like a 4" coupler, i also just cut that off and welded an aluminum 3 1/2" V band onto mine...you can kinda see some pics in my build thread
as for dimensions, i don't know exactly, but a friend of mine had a 76GTS in his turbo hatchback stang and just replaced it with an ST80. the charge pipe's had to be slightly modified and the downpipe had to be changed just a bit, but considering it is a completely different turbo, it went in with very minimal messing around
Old Feb 11, 2008 | 11:57 PM
Zombie's Avatar
So we are right back to square one with no one being able to tell me for a fact the discharge size of the comp housing. I know the inlet is 5" but need a confirmation on the discharge size so I can order the correct coupler. Can someone please measure it? I've asked forced inductions 3 times to let me know the size and have not gotten any kind of confirmation, even after calling them. I need OD dimensions only so I can get the correct coupler.
Old Feb 12, 2008 | 06:02 AM
Yep, Zombie, and I'm still trying to find the answer to this one:
...1. What is the outside diameter of the exhaust housing? If possible, how does this compare to the 76GTS?
Old Feb 12, 2008 | 09:40 AM
DrTurbo's Avatar
LS1TECH Sponsor
4" is the outlet discharge on the cover.
Old Feb 12, 2008 | 11:25 AM
Zombie's Avatar
Muchos Gracias! I'm glad because that's what I already had ordered
That's a hell of a discharge for a turbo lol
Old Feb 12, 2008 | 02:17 PM
DrTurbo's Avatar
LS1TECH Sponsor
Nahh we have some that discharge at 5.1" and have 8" intakes....hehe.
