street killer
Old Feb 6, 2008 | 02:40 PM
dreamls1's Avatar
Default street killer
its that time to buy a turbo. Need help! Looking for 850-1000rwhp on a forged 348ci this is a street car so I need a quick spooling turbo. Its a 6speed with z06 cam and truck manifolds. Would a turbonetics gtk 1000 be good?
Old Feb 6, 2008 | 03:06 PM
BigRich954RR's Avatar
ok first we are going to need alot more info.1000 hp is not easy to do on a street comb with smaller cube inch motors and live. what are your plans
Old Feb 6, 2008 | 03:07 PM
MIGHTYMOUSE's Avatar
one thing i can gaurantee is you aren't going to make 1000rw with a turbo making 1000fw.
it would take an extremely special 76mm to make 1k on the tires at your cubes.
it took me a pte-88 to do it but spool was not so awesome with the 6 speed, though i thought the power was very useable compared to my 76mm which came on too quick and blew the tires off (making more tq and less power)
Old Feb 6, 2008 | 03:08 PM
dreamls1's Avatar
Well, my plans are a weekend car and Maybe to the track once in a while, i just want a quick spooling car. What info do you need
Old Feb 6, 2008 | 03:10 PM
dreamls1's Avatar
what do you recommend?
dreamls1's Avatar
i saw a video your car it is nasty fast.
Old Feb 6, 2008 | 03:13 PM
the car would be more fun as in wheel spin fun with the 76, and easier to package in the car if you are doing a diy kit.
if you get everything else in your car built and handelling say 7-800 at the tires you will find that it is quite a fun ride at that.
Old Feb 6, 2008 | 03:18 PM
stevieturbo's Avatar
Why do you feel you need anywhere near 1000rwhp for a street car ?
I dont have that much, and I can easily break traction til about 150mph on normal road tyres.
Fun in some ways, but for a fast road car, it is rather pointless........even if I do want more power lol.
Old Feb 6, 2008 | 03:51 PM
quicksilverado's Avatar
Find someone with 500-600 rwhp and go for a ride. You may change your mind about your hp goals.
Old Feb 6, 2008 | 03:57 PM
Websy21's Avatar
HAHAHA, no kidding I want 1000rwhp on pump with stock driveabiltiy, LOL
Even though my setup could support 1000fwhp I will seldom use it that often.
Old Feb 6, 2008 | 04:03 PM
dreamls1's Avatar
you guys are right about the hp level. I guess what I am saying is I would like 7-850whp for the street an able to put some race gas in for the track and run around 1000hp
Old Feb 6, 2008 | 06:57 PM
Photochop's Avatar
You need to consider what your goals are (since you'd be annihilating tires and/or other common street cars with less power). If you're wanting to run with bikes and exotics on the highway, 750/750 through a 6 speed will get you there even in a heavy full weight car. If you want ET then start pulling weight and change to an auto and get those cars/bikes out to the track and race em
Old Feb 6, 2008 | 07:56 PM
Websy21's Avatar
7-850rwhp is 1000hp at the crank
Using 850rwhp on the street is allot and good luck hooking that, thats a challenge at its own at the track. I am shooting for 1000hp at the track but won't come near to using that bosot level on the street. Not even 3/4 of that. Probably about 600-650rwhp I'd imagine. About 12psi on pump will be plenty enough You notice most street vids on here from 1000hp cars are toying around on 8-10psi, not the boost level that made them the max power on the dyno. 1000hp is too much for the street IMO, either 650-1000 your are just spinning regardless Unless we're talking on the highway from a roll but I want to see myself atleast hit 30, HAHAHAHA
Old Feb 6, 2008 | 10:26 PM
dreamls1's Avatar
thanks for the good advice! Well what would be a good turbo for the streets in that range?(650whp+)
Old Feb 6, 2008 | 10:32 PM
waterbug1999's Avatar
There is a video I saw somewhere around here the other day, it showed a guy doing 70mph burnouts on DR's on the street. I think he was at ~800 or so.
Old Feb 7, 2008 | 06:58 AM
Firechikn's Avatar
I would say hooking tires on the street with 800 hp is very doable, just depends on the setup. I do it all the time. As mentioned above a small turbo with instaspool, would be the kiss of death. Where as, a larger turbo with a gradual spool over a 3-400 rpm would be able to hook. Even from a slow roll on the street, say 20-30 mph, I can brake spool to 11-12 lb and when I nail it, it will barely shift. Now I do have the 325 MT streets. I don't think you could hook any street tire.
Old Feb 7, 2008 | 07:15 AM
dreamls1's Avatar
So do you thing the Turbonetics GT-k 1000 will spool to fast for the street? Whats another good turbo?
Old Feb 7, 2008 | 07:22 AM
Photochop's Avatar
Pt76gts
Old Feb 7, 2008 | 07:37 AM
98transguy's Avatar
for those kind of levels i would get with Jose from forced inductions and ask him about the st series turbos.probably something like the st76-st-78 would be good
Old Feb 7, 2008 | 07:42 AM
my01ws6's Avatar
Better have a built tranny and rear end to go along with those numbers. While your at it your going to need suspension and everything else too!
Hope you have about $15k saved up.
