PCV what to do with it?
Old Feb 7, 2008 | 01:12 AM
LT1_Fireman's Avatar
Default PCV what to do with it?
ok, I do not like all that oil going in the intake seems like a detonation hazzard.Should i just put on a breather or could i plumb it into the a.i.r. port on the header so it would have some neg pressure to help pull out the excess pressure?oh, I'm making 14~15lbs of boost if that matters.
Old Feb 7, 2008 | 05:10 AM
BOONE's Avatar
What kind of blower do you have?
Old Feb 7, 2008 | 06:26 AM
Reject's Avatar
have you read the thread started by Mighty Mouse on the way he is doing his? he's only making 1000 hp and driving it on the streets, so it may possibly work fo ryou
Old Feb 7, 2008 | 06:33 AM
kwiksilverz28's Avatar
Get a catch can. Check out Mike Norris. He sells them cheap.
Old Feb 7, 2008 | 06:36 AM
TLewis4095's Avatar
https://ls1tech.com/forums/showthrea...=855678&page=3
Old Feb 7, 2008 | 06:54 AM
BOONE's Avatar
If you have a blower hat, plum it from the valve covers to a catch can and then to the blower inlet hat fitting. It has a very strong vacuum and does well enough alone. I dont see a reason for a more complicated system if you have a reg blower with a hat. For a procharger there is no reason for doing any more. I never have any oil in the catch can. I do have a water/oil separater after the catch can that does catch some foamy oil and water but not much.
Old Feb 7, 2008 | 03:32 PM
Its a pro charger D1 .Thanks all for the input.
Old Feb 11, 2008 | 01:22 AM
SonnyG's Avatar
he's only making 1000 hp and driving it on the streets, so it may possibly work fo ryou[/QUOTE]
HAhahah I love you guys....only making 1000hp and still driving it on the streets.....
Old Feb 11, 2008 | 01:25 AM
SonnyG's Avatar
Get yourself a catch can.....I have had good luck with this one.....It looks great too!!!
http://cgi.ebay.com/ebaymotors/OBX-U...em370020179168
Old Feb 11, 2008 | 08:18 AM
Reject's Avatar
MM and Tiago are like the badass's on this forum. they are the cool kids everyone wants to be seen around with lol
Old Feb 28, 2008 | 06:08 PM
TLewis4095's Avatar
Just got one of these in....and there is no baffel system inside to make it effective.
Price on ours goes up on Monday to $69.95 from the introductry $49.95 so get your orders in now.
Old Feb 28, 2008 | 06:23 PM
OreoLt1's Avatar
MY HERO'S
Old Feb 28, 2008 | 07:26 PM
94blownz281's Avatar
use the stock pvc setup off the valve cover,plumb a air/water seperator into that and run the hose to a barb on the blower intake. problem solved. i know a guy doing this with the same amount of boost your looking at and his car has been fine. same system i will be using.
