Kenne Bell install with numbers now as well.
Old 08-27-2008, 12:30 PM
  #201
Z06PSI's Avatar
Originally Posted by Domexitium
This thread pisses me off! and to the OP, f you man. I hate my POS 449 NA junky ls1. you NEED to donate your kb to me with that 383. I'll find a way to make that bitch fit! SEND IT!!
I am in Kuwait right now. Ed is building the motor right now and hopefully will get it this weekend and start to install it. Should be a couple of weeks and it will be good. Had a crank and machine shop issue.
Old 08-27-2008, 01:29 PM
  #202
CHRISPY's Avatar
nevermind...Didn't read the whole thread
Old 08-27-2008, 02:48 PM
  #203
Z06PSI's Avatar
Maybe I should have stated I came back to Kuwait for a week TDY....
Old 09-10-2008, 01:49 PM
  #204
ALL ULL C's Avatar
How's the 383 coming along?
Old 09-10-2008, 07:58 PM
  #205
Z06PSI's Avatar
Going this weekend as I am TDY again this week.
Old 09-24-2008, 01:50 PM
  #206
Z06PSI's Avatar
Update. Got the engine back and will be dropping it in this weekend. Should have a numbers update soon. Don't hold me to it though....
Old 09-24-2008, 03:57 PM
  #207
Restricted User
98Z28CobraKiller's Avatar
Looks like a motor for sure. good luck.
Old 09-24-2008, 09:08 PM
  #208
ALL ULL C's Avatar
Curious as to why ya doweled/girdled it? Was it recommended? Really anticipating results from this combo...
Old 09-24-2008, 09:38 PM
  #209
Z06PSI's Avatar
Well we pan on pushing this combo pretty hard so we wanted to make sure the bottom end stayed where it was supposed to. Lifting the heads will be the next issue as we get aggressive with the tune and start seeing 20-25 psi. with this blower.
Old 09-24-2008, 10:11 PM
  #210
52172's Avatar
at what psi do you expect to run into boost problems? Or have you aleviated that problem with your setup? I recall boost problems a little earlier in your thread?
Old 09-24-2008, 10:33 PM
  #211
DeltaT's Avatar
That motor at high boost is going to be sick in that Z. I am also looking forward to hearing how she feels on the road. Get home safe from the Desert Riviera and fire it up!
Jim
Old 09-25-2008, 07:00 AM
  #212
Z06PSI's Avatar
We didn't have any boost problems but I think some others have had some expectation management with the smaller 2.6L. This year it will be a 750rwhp setup but over the winter I am looking at some differing options with intake tract behind the blower to allow some much higher numbers in the spring after the driveline is sorted out.
Old 09-25-2008, 11:06 AM
  #213
ALL ULL C's Avatar
So is 25psi safe with the 2.8L? I see it's rated at 10-21psi, I would imagine they deem that efficient operating range and not max. As well as RPM the blower is turning too.
So did this originally have the ETP heads and you went from them to CNC'd 317's and now to the TPIS heads?
Old 09-25-2008, 11:14 AM
  #214
Z06PSI's Avatar
No ETP's here.... I am too cheap. 15-21 is the efficient range but 25 is the max and I should be able to get there but the heads will probably be the limiting factor. This years efforts will concentrate on efficiency running as little boost as necessary to get to 750. Next year will be a max effort to push it.
Old 09-25-2008, 04:11 PM
  #215
Nwmembr19's Avatar
I talked with a company recently that says they are designing a 4L twin screw for the ls3,ls9 engines. I am also looking forward to your results, especially with the 2.73 gears and some track times.
Since i have rectangle port heads on my 6.8 i am looking forward to the 4L Plus i'm tired of everyone ******* the pd blower setup. With a big enough twin screw and a well designed intercooler setup, that blower setup should be better than a centrifugal setup. It should definately be more fun either way though.
Old 09-25-2008, 08:16 PM
  #216
Elcaballoloco's Avatar
What kind of numbers do you think max effort and boost will bring? Would that be on race or pump gas? I've been keeping an eye on the build and it's awesome man. I know how it feels to have a ride back in the states thats just begging to me worked on/driven.
What company was this?
Old 09-25-2008, 08:32 PM
  #217
Z06PSI's Avatar
I am back in the states. The latest trip was only for a week.
Old 09-25-2008, 09:59 PM
  #218
Nwmembr19's Avatar
dragon race. the same company that had the 3.3 side mount whipple.
Old 09-26-2008, 12:05 AM
  #219
Johny GTO's Avatar
why with such high boost number, would you only expect 750hp? With a centri and that much boost, you would probably be over 1000hp. I know boost is just measure of restriction and blah blah. I know the are different types of FI, but is a twin screw that much less effecient then a centri or turbo? I know roots blowers are generally, but i thought TS blowers were much more effecient.
Old 09-26-2008, 06:32 AM
  #220
Z06PSI's Avatar
We just don't know at this point. The only example so far in "high boost" application on the two boards I know of was Jeff's 408 and it saw 17-18 psi and made the 800 number. He said they did not push it beyond that as far as I know but he did tell me the blower wasn't anywhere near its max. That is why I said this year (before the snow) we will see how efficient it will be with tuning up to the 750 number with as little boost as possible.
Quick Reply: Kenne Bell install with numbers now as well.
