centrifugal charger vs turbo
Generally speaking, yes. Most would probably say since it's a self-contained unit, you're not running the same oil that you're enigne's using to cool a turbo that can get VERY hot at times (oil does burn and break down faster at higher temps) and less maintenance (from what I've read overall here), as well as less piping to worry about and a more linear power band.
All-in-all blowers and turbos are capable of the same kinda power and track times (unless you go absolutely crazy power, turbo's gonna win out usually) but blowers will make less torque since they're making less boost @ max. cyl. head pressure RPMs. and less power early on.
Might wanna try a search
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I've been around both and can tell that just with the better powerunder the curve (average power though out the RPM band) of a turbo, I would rate 10psi on a centrifugal to about 6-7 psi on a turbo in how fast the car is. Both can make about the same peek number at similar boost psi numbers, but the centrifugal will have a lower average number making it slower overall.
I have driven both types .. An sts turbo ls1 and lt1 and an ati ls1 and ati m6 lt1. The 5 psi sts cars felt as fast or maybe even faster than the 8psi ati cars. Although the ati ls1 was auto, the sts cars were m6 cars. This was going up thru the gears in each car .
The centrifical get more and more boost as rpm increases. This can actually help traction as the turbos can hit hard and put out much more boost much lower in the rpm band. Eg the turbo can hit say full spool at 3000rpm and carry that to redline. The centrifical will put out say 2 psi at 3000, 4 psi at 5000, etc. Just pulling numbers out of my hat but think you can see the principle here. On the track the centrificals turn great times. At the track you are revving them up high so the differences is not as great as going up slowly thru the gears.
You can help centrificals to get up there sooner with things like a stall in an auto and you can gear down if you are in a higher gear in a manual. Downshifting will help of course in the auto too.
One advantage of the magnacharger is they get more boost lower in the rpm bands and have no lag. Bigger turbos will have some lag but v8s help in that department if you don't go huge. I wouldn't be overly worried about the power drain from running the supers. They put out more than enough additonal power to not worry about losing some from parasitic losses.
Reliability is pretty close on both. Turbos have gone 100,000 plus miles on many factory cars. Their is now a mangacharger type setup for our cars. Its nice to have options.
Turbo's can be finicky (is that a word?). tempermental if u will. They all kick *** though. Got my first ride in a turbo car just recently. Twin charged ls1 firebird. holy horse **** batman!!! These things kickied in right before 3k, and wow, it was like be hit in the back by a car!! talk about whip lash!
