what kinda timing you boosted lt1's running?
Old 03-07-2008, 10:49 PM
lt170chevelle's Avatar
Default what kinda timing you boosted lt1's running?
what kinda timing you boosted lt1's running?about to be tuning my pcm
Old 03-08-2008, 01:09 PM
anybody ? i just want a good start for setting a baseline tune .
Old 03-08-2008, 01:35 PM
Purple Poncho's Avatar
Old 03-08-2008, 02:35 PM
98turbls1's Avatar
I'm at 14* right now at WOT because I'm still on a stock shortblock and don't want to blow it... When I get some forged internals I'll up it a couple...
Old 03-09-2008, 09:50 AM
moehorsepower's Avatar
How much Boost ?? first off,5lbs, 20 lbs? people telling you X amount of timing and don't even know how much boost your are running is a recipe for disaster.
Old 03-09-2008, 12:32 PM
engineermike's Avatar
I found ALOT of power going from 26 to 30 deg.
Mike
Old 03-09-2008, 08:11 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
They do like timing. I found over 25hp with every 2 degrees from 22-28 deg. It is better not to go too high, especially if you have a stock bottom end. I would stay at or below 30 on a forged motor & probably below 26 on a stock bottom end for safety. Be careful, pistons & head gaskets are only a keystroke away.
Old 03-09-2008, 09:12 PM
yeah i thought i had posted the boost level i plan on running 5 lbs for now till i can upgrade to a better fuel system.i was thinking maybe 20 degrees to start with, this sound too low?oh yeah can everybody post there boost levels with there timing setup please
Old 03-09-2008, 10:28 PM
...i was thinking maybe 20 degrees to start with, this sound too low?...
Yes .
Old 03-10-2008, 07:13 AM
Waaaay low....
Old 03-10-2008, 08:25 AM
so where would be good starting point? 25 maybe?
Old 03-10-2008, 08:56 AM
25 is still low for 5lbs... but if you want to start from there........
Old 05-21-2011, 12:54 AM
T/A KID's Avatar
Wanted to bring this thread back up
I have an LS1 computer on my Procharged 383 LT4 an I have been looking at timing for LSX cars with similiar setups and many of them run between 15-20 degrees timing.
My setup is an 9.1CR 383 15psi intercooled (115 Iat's without meth) and I have the largest dual nozzle setup from AIS meth (100%) according to you guys I may be able to approach 30 degrees timing??
Also should this timing be at max tq or at Max Rpm?
Old 05-21-2011, 07:48 PM
boosted LT1's Avatar
Each setup is different but a s a general rule LT's seem to accept more timing.
I have a rearmount, with intercooler and meth and run as high as 30 degrees with 14 psi. On my drag car running meth with similiar boost I run <26 and that is with 110 (93 with rearmount).
So I don't think there is a right answer except to say start conservative and add timing slowly...
Good luck
Old 05-21-2011, 10:01 PM
LSx is a totally different animal. The chamber shape is way better, so they require less timing to make max power.
For LTx, the timing requirement doesn't change much with boost. My experience has been that if it makes peak NA power at 36 deg, then that's where it will make peak boosted power. You'd have to run enough Meth to stave off detonation though.
Old 05-24-2011, 08:11 PM
T/A KID's Avatar
THanks for posting guys, seems like I kept seeing LSX engines run high teens with timing and I thought we usually run mid 20- low 30's at WOT. You guys have any files I could look at??
The thing I am seeing as the timing on the LSX computer is Spark vs RPM Vs cylinder airmass (grams/cyl) and tunercats uses spark VS RPM VS Map (KPA) I don' know how to convert that??
Old 05-24-2011, 09:32 PM
I got your PM. I do have some old files, but didn't keep good track of what was what. I probably have 40 or so files with different stuff in them. Also, mine was a 2 bar SD tune with O2's disabled, plus I used Methanol for some of the fuel and on top of that a Crane HI 6 TR to pull the timing down. I have no idea what timing I was running, but it seemed to run good.
Old 08-06-2011, 01:20 AM
forgedlt4's Avatar
im an lt4 383, with 11.3:1 compression E-85, and on 10 lbs.
im at 21 deg locked.
you guys think there is more in it?
Old 08-06-2011, 01:53 AM
Fbodyjunkie06's Avatar
With E85 you should have a little more room for error try 2 degrees at time.
It seems like tuning on these LTx car's is a lost art and the ones that really know wont say **** about what they really know.
Old 09-12-2011, 07:43 PM
T/A KID's Avatar
Considering how much timing we run at WOT, would extra timing at idle and part throttle be higher compared to a LSX engine? I believe I seen some LT1 cammed guys running around 35 degrees at idle, where as most LSx engines I have seen are around 25?
Quick Reply: what kinda timing you boosted lt1's running?
