17 year old turbo pics
Looks good and when is it getting tune/running right?
Jerrad
Wouldn't the charge piping move with the suspension if it is suspended from the rear axle on the pass. side rear?
Also what is the device that acts as your 90deg. into the intake? Not sure of the design internally but wouldn't it slow down/decrease efficiency if it is not a smmoth curve into the intake?
Once again not critcism just honest ?'s and possible pointers!
Without having access to mandrel bending machine and some people with serious fabrication skills its going to be hard to make a system that works well and doesn't drag on the ground and rip off the first speed bump or train track you go over.
If the used sts or used frontmount kit is still too much I would go for heads,cam ,headers or possibly nitrous route. With carefuly shopping they could be done for 1000 to 2000 especially if you shop used on the boards.And you can do heads,cam and heads as budget permits or nitrous on a stock engine with a few safeguards and upgrades..fuel pump,window switch to name two.
I think you have bit off a bit too much here. We would like you to succeed,its great to try out stuff but this is starting to remind me of some honda setups I have seen in the past.
Again please don't take this the wrong way but its hard to do a good turbo system without spending some good amounts of money.
Remember a set of truck manifolds, box of 2.5in bends and some flanges are all inexpensive to purchase. It really isn't that hard to do a FM with a set of truck manifolds at all.
J
I hope you get it lined out, but more often than not a home grown turbo kit (especially rear mounts) have alot of trouble making the power they're capable of due to insufficient piping and lack of a good cool intake charge. But hey, if I doesn't work out it's a good experience and you can always sell that turbo for a good set of ported heads and a cam that will require much less time/effort to make similar power.
I commend you on the effort, hopefully you could get some of these issues taken care of.
What i see:
Maf placement
piping size
clamp type/ connector type (may want to try bead rolling if you can)
What i see:
Maf placement
piping size
You need to move the mass air upfront closer to the throttle body. The mass air I don't think would even read correctly with that long of a wire extension(from what I hear)
Also you need to just buy a 90* coupler to put on the throttle body and do away with what you got that will probably kill your hp and boost.
So far it looks like your headed in the right direction just needs to make some changes. Also PLEASE get that thing tuned before you make ANY boost or you'll probably be looking for a new block. Atleast a base tune!!!! You also need to change injectors out and the fuel pump. On my car I have already ran out pump at only 5 p.s.i. with a 255lph walboro. So you really need one of those.
It looks like in that last pic you have the exhaust side of the turbo mounted to the panhard bar. I might be wrong on that but that is what it looks like to me.
http://www.ststurbo.com/ls1_installation_pics This is what you want it to look like!
Sean
My hat's off to you for even trying a project like this - don't give up, you just need to chip away at each problem as it comes. That's what pioneers do...
Jim
do some more research and you'll get it.
