HELP...Boost gauge issues.
Old Mar 16, 2008 | 04:25 PM
sworaz's Avatar
Default HELP...Boost gauge issues.
Boost gauge wiring says to have one of the wires go to Ignition 12v source....what does that mean? I know I already have my powercooler wired into the ignition relay but I can't imagine i'm supposed to have that wire, my boost wire and the two for my fuel pressure gauge all wired to the same ignition relay.....
Old Mar 16, 2008 | 04:52 PM
Derek @ EDO's Avatar
Go buy this "ADD A CIRCUIT" deal at your local auto parts store.
hook up the power wire to the butt connector and
Plug it into your radio fuse spot.
Thats how i wired all of my gauges, works great!
Old Mar 16, 2008 | 08:57 PM
sworaz's Avatar
That's cool, thanks for the response. But doesn't really answer my question:
What is the ignition switch 12v (+) ? I have 3 wires that need to go to it, so I have to know exactly what it is.
Old Mar 16, 2008 | 09:15 PM
Its a switched power wire. Your radio does not get power until the key is turned on so thats why i used it for an example.
Old Mar 16, 2008 | 09:31 PM
sworaz's Avatar
Ok, so your saying that it isn't necessarily the Ignition switch or fuse, correct? Just any key-on fuse/power source?
If I have three wires that need to go to this type of source...would that part you posted work for all 3?
Old Mar 16, 2008 | 09:35 PM
OreoLt1's Avatar
A power source that only has power when the ignition switch is on the on/run or accessory position.
Good find Derek @ EDO. Looks like a good part to use.
Old Mar 16, 2008 | 09:36 PM
sworaz's Avatar
Alrighty, thanks.
Old Mar 16, 2008 | 09:51 PM
Yep, I have all 3 of mine hooked up to it!
Old Mar 16, 2008 | 10:42 PM
sworaz's Avatar
Ok so just wire all three together in the connector and crimp it off? Also what Auto parts chain has them? I just looked on auto zone and couldn't find it.
Old Mar 23, 2008 | 03:09 AM
Raptor_WS6's Avatar
what gauges did you go with
Old Mar 23, 2008 | 08:07 AM
sworaz's Avatar
I went with Prosport, very nice gauges.
Old Mar 23, 2008 | 09:13 AM
mcx's Avatar
mcx
nice idea..i've never seen those before?? are they rated with differant fuse settings??
Old Mar 23, 2008 | 09:17 AM
sworaz's Avatar
I thought that thing was a cool product too.....I asked every part store in town and none of them had it
