Budget Borg Warners
also, would a bigger s series bolt up since it has the same t6 flange and it is slightly smaller in size?
double also, can this unit work with a stock cubed stoick bottom end at about 5psi similarly to a tc76 until it getts a better bottom end? is there a better comparison to the tc76 in terms of power
hrmmm the S400-72
guessin its a 72MM inlet, given i add the t4 turbine housing. how much of a difference is the turbo from an S372 ?? non ETT ? too big of a turbine wheel ?
-Mike
Marty
. Some people half-*** a setup to make it cheap and then end up spending more money again. Do it right the first time...cheaper that way in the long run. We have many customers that have bought the stock S400's and are NOT happy with spool up and they end up selling for a loss and starting over again. Not what I would call smart.....but to each his own. I will say it once and then say it a million times,they are good race turbos....if you have a daily car you enjoy driving and want quick spool, look at something else...plain and simple. We sell a shitload of these turbos and they perform great for the proper application.
he's not lying about that LOL....
