Budget Borg Warners
Old Mar 17, 2008 | 11:58 AM
DrTurbo's Avatar
LS1TECH Sponsor
Default Budget Borg Warners
For those asking us to offer the budget Borg Warners on the site...they are now included on the site. Just nagivate to the bottom of the site. Parts are on the shelf for them.....
http://forcedinductions.com/productsborgwarner.htm
Old Mar 17, 2008 | 11:59 AM
Fireball's Avatar
wow...great prices
Old Mar 17, 2008 | 12:06 PM
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by Fireball
wow...great prices
Yes they are cheap, but don't expect instant spool....lol. They are straight off BIG diesels. They will work pretty good on some applications such as race cars.
Old Mar 17, 2008 | 12:14 PM
Fireball's Avatar
I don't think my new turbo will exactly have instant spool either
Old Mar 17, 2008 | 12:16 PM
DrTurbo's Avatar
LS1TECH Sponsor
Well its also not rated no where near 1100hp........lol. Your is rated enough to move a small oceanliner....hehe
Old Mar 17, 2008 | 12:36 PM
Drew04GTO's Avatar
Does that mean dynamic seals or whatever they're called for diesel apps?
Old Mar 17, 2008 | 12:43 PM
DrTurbo's Avatar
LS1TECH Sponsor
Almost all current turbos from all the manufactures use dynamic seal in this present time.
Old Mar 17, 2008 | 12:48 PM
Drew04GTO's Avatar
Was going to buy a set of headers this weekend but it turns out I might be giving you a call instead. Wicked deals on these.
So is it the turbine wheel that makes it slower spooling? Trying to figure out what it is that's different between diesel and gas apps if they both have the same seals.
Old Mar 17, 2008 | 01:09 PM
1INSANEGTO's Avatar
Damn talk about a budget build for twin. Hell they make compression and 2 steps for spooling
Old Mar 17, 2008 | 03:26 PM
mike06tork's Avatar
will this turbos work good or a 370ci. 6.0l with the S475 turbo 1.10ar with the T4 turbine housing and will spool pretty quik on a daily driver ????? anybody
Old Mar 17, 2008 | 03:27 PM
mike06tork's Avatar
round what rpm will it be at full spool 12# of boost??? i have a 3000 torque converter on a 2006 silverado single cab.
Old Mar 17, 2008 | 04:21 PM
DrTurbo's Avatar
LS1TECH Sponsor
It will work on a 370, and spool decent. Its not instant spoolup by any means, but it will make some good power for sure.
Old Mar 17, 2008 | 04:22 PM
DrTurbo's Avatar
LS1TECH Sponsor
It would be somwhere in the 3500-3800rpm range depending on tuning, compression, and cam specs.
Old Mar 17, 2008 | 04:53 PM
Grr's Avatar
Grr
i have the standard s475 with 1.32 a/r on a stock 6.0 with a cam. I see boost off idle around 32-3500, and my full 10psi around 4200. That is with the stock 1700 stall in the 4l80e as well. Sure they dont spool that fast, but the $6-700 you save is well spent elsewhere to make up for it. Also once you get these things moving, they make rediculous power
Gary
Old Mar 17, 2008 | 04:56 PM
deadmanTA's Avatar
Got to check these out!
Old Mar 17, 2008 | 05:27 PM
DMH Fabrication's Avatar
price on a Borg Warners 362 and 366?
Old Mar 17, 2008 | 11:04 PM
Hennytime's Avatar
how large are these turbos compared to the s series bw units or even the tc76 (specifically the 1000hp capable s400-75 t6-96 framed/1.32a/r)
Old Mar 18, 2008 | 12:49 AM
Mr.MartyStone's Avatar
Why do you only list the S480 to 1100hp? Didn't you just post a graph of it making 1330hp maxed out? Just wondering why you guys always underrate these things.
Marty
Old Mar 18, 2008 | 08:42 AM
DrTurbo's Avatar
LS1TECH Sponsor
Marty
Manufacture ratings....., plus those in the graphs are race cover units, not standard BW units.
Old Mar 18, 2008 | 08:44 AM
DrTurbo's Avatar
LS1TECH Sponsor
A S400-80 with stock cover is a little larger then a S91. Its longer and taller.
The TC76 is a micro turbo compared to the Borg Warners.
