AIS methanol results
I have the AIS methanol kit that mounts in the trunk. EASY install and holds 1.5 gallons of meth. I got the progressive controller and the 6gph and 12gph nozzles.
I went to the track with some low boost this weekend....about 600rwhp to test it out. Only log i kept (laptop battery kept dying) my IATs started at 87 degrees at the line...ended at 59 degrees at the end of the 1/4...ambient was 62 degrees. I will have more results with more boost after the 30th.
Rodney has been GREAT to deal with. Oh...I am running straight methanol..no water.
Sounds like everything is working out good for you know. Post some pictures of your car if you have a chance. Thanks for the support, nice working with you.
Rodney
LS1Tech Sponsor
+1, Really interested to see how its mounted and ran in an f-body. I currently have the snow kit but am running out of room under the hood to mount my tank. Curious where all the lines run as well. Now sure i like the idea of straight meth running the length of my car but if it works, proven and safe, then it cant be a bad idea!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
i routed the line just like you would an n20 line.
under carpet, behind threw the pass side kick panel and runner, then thru the grommet at pcm area.
spare tire area...yeah, it will fit but wont sit all the way down on the btm, you might have to make a floor for it to keep it level. but sliding it down in there is no biggy. the anten support makes it a little tight but it fits.
im happy with the package, literally less than 1hr install not including nozzle to tb drill/tapping..it works as described.
this car (v6 turbo) had trouble with kr at any timing above 13-14* with 15lbs boost..i can now lock in 20* with 20-22lbs boost and no kr..but i am running the dual nozzle kit. it works. im happy with it
cablebandit, those numbers look great. Don't know if you've mentioned it or not, but do you run an intercooler too?
I know everybody will say get an intercooler PLUS a methanol kit, but, what do you guys have to say about running only a meth kit on a street/strip car at nothing more than 15 lbs of boost? Reliable and beneficial enough for a car that is not an all out race car?
you should try spraying pre turbo!!! on 90-100 deg days it will frost up your intake. and we did it with gas not meth lol. no IC and sub 25 deg IAT's gotta love it!!!!! i really like the kit they sell i will be installing one on my starquest very soon!!!! the old NOS fuel solinoid has seen too much time for the real deal lol...
i would not run a meth line in the car!!!!!!!!!!! not legal and most of all not safe!!!!!!! i know we all have done the easy way alot of times but why chance it meth gets real hot lol and very hard to see the flame in day light. just dont want to see anyone get burnt!!!! It does happen so thing twice where to run the line!!!!!
Well thats good cause i saw a buddys mustang go up in flames at half trck at about 130mph because of lines being mis routed!!!! and we all are lucky he made it out!!!!!! just looking out
