Anybody have F Body APS Results? Dyno and or 1/4 times
no they are not for the dyno sheet its in the dyno and compro. look for 2000 z28+APS = 700rwhp my tuner put it up there it has a the info good luck with your set up you are going to love it
https://ls1tech.com/forums/dynamometer-results-comparisons/874527-2000-z28-aps-700rwhp.html
here is that link man
you can see the boost creep up to 12 psi
sweet Tom can't wait to see what you run. What are you running for a tranny and rear end?
Hey TNT you got some ***** running a stock rear end with all that power. However i've got the same ***** you do because i'll be running the stock rear end for a little while also or at least till it blows up...............NICE!!!!!!!
i have an aps kit. waiting for rest of motor parts. Going with a LS3/L92 block(377ci) 9.5 or 9.8 compression (haven't decided), callies crank, oliver rods, diamond pistons, afr 225 heads, ls2 intake, cam (haven't picked). looking at running all psi i can. kit says 18psi. so we'll see. and run e-85. **** is cheap around here. 91 oct is $3.45. e-85(100+ oct) is $2.50
anyways
e-70=100oct
e-80=?
e-85=105-106oct
nice thing is i can run high boost with 9.5:1 to 10:1 compression and not have to worry to much. and not have to rely on meth. it just uses a bit more fuel. i got to plan on using 20 to 30% more. witch works out to about the same as pump gas. but i am runing 100+ oct not 91oct. so it all works out.
https://ls1tech.com/forums/showthread.php?t=874527
in the winter is is called e-85, but is like e-70. to cold for cars to start on e-85.
anyways
e-70=100oct
e-80=?
e-85=105-106oct
anyways
e-70=100oct
e-80=?
e-85=105-106oct
I think you need a lot larger injectors for e85?? Its great stuff many guys run it on many other turbo cars on various boards very successfully. Only problem is its still not everywhere. We have only three stations on all of canada yet they are selling new vehicles with flexfuel engines up here? Hoping it starts becoming common.
My aps kit is also in the boxes. Got it too near end of season last year so decided to
wait till spring and then decided to get new engine built. At least this way won't be worried much if do go to higher boost.
Only other good thing about waiting is get to see you other guys do your kits and pick up tips to hopefully help when do mine. Hoping to have mine done by july1 latest.
Fuel demand is roughly 40% additional, take injector flow for gasoline, multiply by 1.4
http://www.eere.energy.gov/afdc/pdfs/40244.pdf
Mine only made it one round! Took it to the track a couple weeks ago and it broke the rear on the second pass. I'm hoping for the 9" to show from moser any day now.
Not sure what kind of horsepower it's making but on my first pass it ran a 6.69@107 with a 1.56 60 foot. Sorry, only 1/8th mile track here locally. Second pass, it stripped the gears out of the differential. Auburn Pro.
This is on an 8.35:1 CR 370 cubic in with Dart heads running about 10 pounds of boost on the wastegate spring.
it held for 3 years on a 150 hit so hopefully it'll last just a little while longer...i know im askin alot but oh well, if it breaks,(and it will) it breaks
