Superman V.3
thanks man! keep me posted!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Not sure if you guys even have a camera around but if you do i'd greatly appreciate it! Thanks!
Final #s
12.5 lbs.
666.6 Hp
640.4 torque
It only made it to 6330 before it sucked the inlets shut
At least it didn't run out fuel.
It will be aligned tomorrow afternoon should be able to pick it up on Wed.
Brent
Did you upgrade your smaller turbos. Haven't heard much from you on it lately assume you are playing with your vette maybe? Any other issues with your APS setup. You are still my hero there JM. 9s and a great mph.
Peter seems to not be on this forum much anymore. He comes on and makes a quick comment or two on some post but we are not getting straight answers from APS or him. Are they coming out with new intake tubes for the standard kit or not? Are they ready to buy.The time change makes it annoying to phone APS directly but maybe thats what has to be done.
I still don't have my car together. Was waiting on engine from Canadian Performance for a long time and of course there was some very bad news from there. I am looking at an empty engine bay and waiting for a motor to get my project going. At least that gives me some time to see the problems other guys are having with their setups. I would think should be able to put in some flex steel hose or something to stop them from sucking shut. I wish had mine on my car would MGUYVER something.I am usually handy at that stuff.
Also now the cooling issue has come up. Wondering if need to order the edelbrock water pump and maybe a lt1? rad or some better rad. The be cool say good to 400 hp ? thats no where near enough.
It for sure seems that APS has a problem with these sucking shut,we have heard it several times already.They need to bring out a fix and bring it out ASAP. And it should be free. The system is rated to do like 1000 engine hp and it is going to need more than 12psi to do it on most combos.
I am hoping can get close to it on mine maybe at 15psi but how can I do that if the intakes suck shut at 12psi.
Peter please give us some decent updates on this issue any other issues that come up. You were on the board constantly when we were buying our systems and if you are not in position to be on the board much anymore maybe someone there can take your place or we need contact numbers direct at APS for these issues. And Peter I assume you will read this post you read most posts about APS turbo installs I think.
We can do custom ducts if interested, its all money
This thing sounds mean when boost hits
Locked converter so not much less then a stick.
