Superman V.3
Old Jun 16, 2008 | 05:03 PM
  #121
MY99TAWS6's Avatar
I might be interesting in those custom ducts since APS seems to no be taking care of us took quickly if at all??? I for sure dont' want my inlets sucking shut. Pm me pics and prices if you like.
Old Jun 16, 2008 | 05:21 PM
  #122
JBrady's Avatar
Originally Posted by Brent@EPP
Alright
Final #s
12.5 lbs.
666.6 Hp
640.4 torque
It only made it to 6330 before it sucked the inlets shut
At least it didn't run out fuel.
It will be aligned tomorrow afternoon should be able to pick it up on Wed.
Brent
Hmmm... are they physically colapsing? Or, are they just causing a drop in boost due to restriction? What are the symptoms at 6300rpm?
I suggested here:
https://ls1tech.com/forums/showthrea...120&highlight=
a fix on the C5 system that I had recommended some time back on CF and that is to use the pancake tube sections as the compressor outlets and create new inlets similar to the new APS design for the new C6 ZO6 system. Doing this gives maximum area potential for creating the least restrictive air path to the compressor inlets.
Old problematic C5 layout
Revised C6 ZO6 layout
Old Jun 16, 2008 | 05:33 PM
  #123
obZidian's Avatar
oh, those are locked numbers.... my bad!!
Non the less, still enough power to have plenty of fun through that 4l60e!!!
Old Jun 16, 2008 | 07:08 PM
  #124
30th t/a's Avatar
666rwhp is a mean number for the street
Once you get those ducts corrected you should have 700 easy. That sucks after you spend all that money you get some bullshit problem. hopefully you get it fixed soon.
Old Jun 16, 2008 | 07:12 PM
  #125
Jake@EPP's Avatar
This is the 3rd car with issues on them, the other 2 had UMI k members.
But it sucks shut at the ovalized part on the driver duct, and also on the elbow portion on the driver duct. I watched it suck shut on one car, the boost lays down as if one turbo is offline.
  #126
Superman09's Avatar
LS1Tech Sponsor
Yea, i PMd peter about it. Funny how their kit made for 1000 engine hp only made it to 667 rwhp. Little pissed about that, but other than that minor issue i am happy as **** with the results!
HUGE thanks and big applause to the guys at EPP! Hopefully i can come down real soon to pick it up! I still cant wait to see that front end with the trick cooler set-up and hear the idle and WOT sound!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 16, 2008 | 07:21 PM
  #127
MY99TAWS6's Avatar
I don't think they said they could get 1000 engine hp necessarily from any combo of engine size but that it could potentially get that number as that was what the turbos could flow. 50 pounds a minute is usually translated to 500 hp engine per side roughly.
Now Jm has gotten close to the magic 800 rwhp on an auto number which if figure 20% for auto is 1000 engine. His engine is of course a 402 not a 346 and he has expensive heads,etc.
Still think there might be another 80rwhp or whatever in his combo if he could get them up a bit higher on boost.
So don't think aps has lied and they did get higher boost numbers think like 18 or 20 psi out of their kit not sure why theirs were not sucking shut.
Anyway this sucking shut problem should be simple to fix for a company as big as APS. And EPP already said they can maybe sell us a solution if need be.
Old Jun 16, 2008 | 07:24 PM
  #128
Superman09's Avatar
LS1Tech Sponsor
yea, stainless custom ducts would be very pricey i have a feeling though. APS needs to pull through and correct this problem!
__________________
Old Jun 16, 2008 | 07:31 PM
  #129
RUNINHOT's Avatar
What exhaust setup did you end up with on your car.
Old Jun 16, 2008 | 07:32 PM
  #130
Superman09's Avatar
LS1Tech Sponsor
ORY and Magnaflow catback......
__________________
Old Jun 16, 2008 | 08:12 PM
  #131
Darren P's Avatar
I have not seen it yet but I am pretty sure my car is sucking shut as well. It made around 650 RWHP on the dyno but when I attempted to up the boost at the track it went from a 10.2 to a 11.6 and went from 12~13 pounds at the line to ~5 at the traps with a 118 MPH trap speed.
on spring alone it ran a11.2 at 133 MPH
and now the over heating problems
Old Jun 16, 2008 | 08:22 PM
  #132
30th t/a's Avatar
where your number through the full exhaust or cutouts? if you got cutouts?
Old Jun 16, 2008 | 08:24 PM
  #133
JMBLOWNWS6's Avatar
Mine have not sucked shut yet. Peter did offer me the upgrades. ALL THE UPGRADES ARE IS MORE LAYERS OF SILICONE. I told hime I would wait till the upgraded turbo's were done for me. The new ducts are $125 FYI. I also dont have any overheating problems. But I am running a electric water pump and I dont get into alot of traffic. But I havent driven my car in about a month.
Old Jun 16, 2008 | 08:31 PM
  #134
Superman09's Avatar
LS1Tech Sponsor
Through the Magnaflow.... no cutout on the car
__________________
Old Jun 16, 2008 | 08:40 PM
  #135
Darren P's Avatar
have you driven it in 90* + heat yet.
I may have to make me some metal ducts if that is all it is. Or do like one local guy here and put filter on the turbo directly
Old Jun 16, 2008 | 08:43 PM
  #136
Jake@EPP's Avatar
Metal ducts are the real deal, we had used some high temp spiral brake duct hose as a temp for a guy since his wouldn't make more then 5psi and then suck shut. It looks like they get worn out and then the ducts just suck shut out of no where.
Old Jun 16, 2008 | 08:48 PM
  #137
JMBLOWNWS6's Avatar
97 here bud. Im in Texas! But I dont drive my car daily anyway. To the track and back and to car meets.
Old Jun 16, 2008 | 08:49 PM
  #138
JMBLOWNWS6's Avatar
Well make us some and maybe we will buy them.
Old Jun 16, 2008 | 08:50 PM
  #139
Superman09's Avatar
LS1Tech Sponsor
you can use my car as a prototype! Long as you leave them on there free of charge
__________________
Old Jun 16, 2008 | 08:52 PM
  #140
JMBLOWNWS6's Avatar
Its funny now but brings up a good point when I made that thread a while back about the ducts. Just a matter of time till all of them do it.
