Opinions on MagnaCharger?
http://www.youtube.com/watch?v=s4brxHNWdQE
The road started to end a little faster then I thought lol. Not many straight roads where I live You will notice my brakes work well
http://www.youtube.com/watch?v=7cyrWJ5B6Oc
Small punch on the bridge
http://www.youtube.com/watch?v=hvAkwZE2QgM
Simple driveby lol. Can you hear the blower?
http://www.youtube.com/watch?v=WY4qRAJG64I
Dyno Run (dyno numbers are with current mods and a rich AFR low 10's-11's)
http://www.youtube.com/watch?v=eBZI3RU09C8
This video is the first setup I had with it. It does not sound like that anymore I just added the vid so you can hear what it was with the heads, headers, cam and LMI
http://www.youtube.com/watch?v=4fAS1070FBY
And one on my C6 vette on the dyno too.
http://www.youtube.com/watch?v=Rjib7luyh3w
I am thinking about putting a maggie on a 6.0 LQ4. I am gonna swap the intake and cam for starters, not sure about the heads.
Damon
I talked extensively with Ed from LM SPeed before I ordered the kit. He said that the maggie is happiest around 9.5 compression, so i would say that your 9.4 is good. I would recommend a forged short block, due to reliability with more than 7psi boost. 500rwhp is not that hard to get with the maggie. My cam is the SC-3 from Speed Inc, it's in the blower grind section on their site. I actually got my heads which are 243's from LM Speed. He gets them from Livernois and were machined to get 72cc combustion chambers, they were $1300 and with the numbers from Ed they appear to be Livernois Stage II heads. If you already have 317's I'd stick with them though. My cam was $400 or so. There are many good cams out there for boosted apps, just got to ask the right people. Most of the sponsors here have something for your needs all you gotta do is call and ask some ???'s. Comp Cams techline is a big help too. If you really want this kit, it takes some cutting of the cowl and welding a small 3"X11" or so patch, but it's not that complicated. Ed recommends dropping the motor to put the patch in, but I didn't, I just sat on the top of the motor and contorted myself enough to get it done. It would have been MUCH easier to do with the motor out, but it isn't a must. I used a skinny friend to weld so he could under the cowl easier than my fat self.
I am still trying to get my tune tweaked right, but it's fun. Running about 60 on the freeway and stomping the pedal to get the boost in and just spinning the rear tires is quite different from what I'm used to. The whine is awesome. Last edited by discostu; Apr 5, 2008 at 04:54 AM.
Maggie C5 ZO6 full bolt ons VS my 408 SS NA.
http://videos.streetfire.net/video/m...-408_33888.htm
I lost to a procharger setup on a ZO6.
Yea magnacharger does not make a blower that makes 700-800
http://videos.streetfire.net/video/9...YNO_154043.htm
Funny that looks like a magnacharger to me. My reference to 400RWTQ down low is more of an example of how there is power under the curve. IF you want to wait for boost fine. At the track anyone who is not supporting thier setups with a proper suspension wasted alot of money. No fun watching cars create smoke. Last race I did having that power under the curve helps during shifts, and helps load stalls. There is alot more to it of course and more info up for debate but to say the power under the curve is not needed, well that is for the individual to decide. No right or wrong answer really.
Badmonkey, Farmdawg: what track times did your cars run with the Maggie?
I'd love to know, because I'm considering a maggie setup just because nobody around me has done one. But I'm sure it won't feed my 408.
