crankcase pressure
http://www.ls1speed.com/cont.cfm?cid=C0000193
or it could be the rings..but i think you would be pushing water out the overflow too.
The blown head gasket is where the air is getting in...from the piston(s) pushing the air through the blown part of the gasket into the coolant on the compression stroke. The white smoke coming out of your exhaust is coolant being burned and blasted out because on the downstroke it sucks coolant through the blown part of the gasket into the cylinder.
Thats how I understand it anyway.
