What FI set up should I use with 414ci
Well I am going to rebuild my motor so I can do a FI set up. What comp should I build it to and what set up should I do? Turbo? or S/C? Whats the advant and disadvan about both? I was looking at prochargers D1 or a F1. What would the power diff between both or the power diff of a s/c vs turbo. This is a 6 spd street car and I will take it to the track sometimes. The heads I have are the TEA/TFS 235 with a ported fast 90/90. I would like to make 750rwhp on pump gas. Please post any info or your dynos. I am new to the FI scene so any info will help. Thanks
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
![](http://i242.photobucket.com/albums/ff5/ExoticPerformancePlus/Bob809RWHP1.jpg)
809 rwhp at 14.4 psi of boost from an ATI ProCharger F-1A on 93 octane fuel our Mustang Chassis Dyno. This is on an LS2 402 with AFR heads. Bob
You can't go wrong with either setups (i.e. Turbo or Supercharger), every kit has it's pros/cons but it's up to you to choose what you feel is best for your application/goal(s). My being in California, my options are limited to Procharger and STS. I choose to go with Procharger instead because although STS kits do put down decent numbers, where I live that turbo would get torn up big time.
LS1Tech Sponsor
Here is a 8.8 compression 427ci with a D1 at 12lbs,ETP 225's and 232 duration Cam.Car drives like stock,idles at 800rpm and makes a great average power very reliably.The owner has about 60 passes,15k miles and numerous broken driveline parts to prove the power.A real pleasure to drive.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
The power gain shows what 2 degree's of timing does.The car is still very detuned for the driver.
