You guys with a VAC/BOOST gauge... what vac are you seeing at idle?
Old 04-24-2008, 12:19 AM
Avengeance's Avatar
Question You guys with a VAC/BOOST gauge... what vac are you seeing at idle?
Just curious... I dont think my boost gauge is working correctly and would like to know what is "normal"? I know all cars will be different.. but what is yours showing for VAC at idle?
Thanks.
Old 04-24-2008, 12:30 AM
BigBlockCamaro's Avatar
I see about 20 lbs of vaccum at idle.. dont know if its good or bad! but thats what I see..
Old 04-24-2008, 12:43 AM
chewy99ws6's Avatar
I see close to the same as stated above, between 15 and 20 at idle
Old 04-24-2008, 12:45 AM
Avengeance's Avatar
Right now Im seeing 11-12 in/hg at idle.
Stock LS1, 6.0L heads, blower cam 221/227 580s 114... D1SC.
Well.. while Im here I might as well ask....
Setting my AFPR... do I set base FP w/o the vac hooked up? So at 0psi its a true 58psi?
Old 04-24-2008, 01:02 AM
calongo_SS's Avatar
yes
vac at idle will depend mainly on cam size. with a small cam I am seein 18-19 in/hg at idle.
Old 04-24-2008, 01:13 AM
Closed Sponsor Account
Josh@MASPORT's Avatar
21-22inches here
Old 04-24-2008, 01:14 AM
ninetres's Avatar
9in-lbs
BIG cam lol
Old 04-24-2008, 01:21 AM
Avengeance's Avatar
Thanks guys...
I dont consider my cam big... 221/227 .588/.575 114lsa. I know its registering more then 10".... maybe its 13".
Old 04-24-2008, 02:04 AM
SRZ
SRZ's Avatar
Originally Posted by ninetres
9in-lbs
BIG cam lol
Don't feel bad I'm at 7-8". LOL!
Old 04-24-2008, 08:01 AM
SPRAYED 01's Avatar
15 at idle
Old 04-24-2008, 08:14 AM
trans2000am's Avatar
i was seeing 20
Old 04-24-2008, 08:22 AM
smoke20's Avatar
18 at the moment
Old 04-24-2008, 08:23 AM
No Juice's Avatar
with a stock motor, stock cam & stock heads I see about 22-24 inches of vac
Old 04-24-2008, 08:40 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
With my 347 9.35:1 with speed inc SC2 cam (224/232 .581/.595 114) AFR 225 72cc heads I get around 12-15 in/Hg at idle. When cruising on the highway it often goes to 20 in/Hg.
Old 04-24-2008, 09:13 AM
MECHAM's Avatar
there is no magic answer to this question...it depends on mods, cam, your altitude.
just remember what it is now and take that as normal unless you have a leak
Old 04-24-2008, 09:15 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I am seeing about 8 to 9. Big *** cam
Keith
Old 04-24-2008, 09:31 AM
Avengeance's Avatar
Thats kind of what I figured. I thought mine was a little low but I suppose with a cam and 6.0L heads its possibly normal?
Old 04-24-2008, 11:03 AM
b727pic's Avatar
18-20 hg for me @ 800 RPM idle
Old 04-24-2008, 12:39 PM
4SFEDZ's Avatar
10 @ 800 rpm!
Old 04-24-2008, 01:06 PM
cablebandit's Avatar
10@725rpms
