good cam for a procharged 402?
Old May 4, 2008 | 12:05 PM
Disturbed Bird's Avatar
Default good cam for a procharged 402?
i would like it to be tame and not vary radical, and still get good gas milage wile at crusing speed. thanks.
Old May 4, 2008 | 12:27 PM
mightyquickz28's Avatar
Contact Bret Bauer with your spec's and let him find one for you.
Old May 4, 2008 | 03:55 PM
jmdgto's Avatar
call bob at epp for his epp cam.
Old May 4, 2008 | 03:58 PM
transamfreak01's Avatar
+2 on calling bob. he knows his ****
Old May 4, 2008 | 04:59 PM
Jake@EPP's Avatar
It would help out alot if we knew a bit more about the setup?
Heads , Stick/auto , blower , pulley combo , rpm range desired , gears.
They all go hand in hand.
Old May 4, 2008 | 06:39 PM
the setup is a 402 9.5:1 CR. ported L92 heads, L76 intake, 90mm throttle body, stage 4 t56, d1 blower 12 psi, 4:10 rear gear.
not sure on the rpm range.
just looking to make 800+ at the wheel with mostly the blower.
i would like to keep vary good gas mileage in the city and highway, and be vary street able.
i know this is hard to accomplish.
Old May 4, 2008 | 07:10 PM
Jake@EPP's Avatar
The blower will need to be maxxed out to provide that amount of hp. A 3.40 pulley is about needed to put impeller speed up there.
We offer a stage 2 cam for 400in motors, it is a 236/246 114 .604 / 610
Old May 4, 2008 | 08:03 PM
Slowhawk's Avatar
LS1Tech Sponsor
With that head/Intake tame down the Cams.Use a high lift high 220's intake with 10 degree's split to the exhaust. Big Cams are crap with boosted L92 heads.
Old May 4, 2008 | 08:26 PM
what kind of gas mileage has been reported with that cam and setup?
Old May 4, 2008 | 08:44 PM
Jake@EPP's Avatar
I cant say ive every had anyone comment about milage Most are usually too busy pressing the loud pedal.
Old May 5, 2008 | 04:34 AM
EPP's Avatar
EPP
It sounds like our original blower cam is more in line with what you are looking for. We have it in this Cadillac CTS-V that has a 402 in it. Here is the dyno graph from this V.
We just installed this camshaft into a GTO that we drove 120 miles yesterday (Sunday) to the Indianapolis airport, for the owner to pick his car up and drive it back to Kansas. It was getting 21 mpg on the way to the airport.
Here is a link to this camshaft.
http://www.exoticperformanceplus.com....html?item=679 Bob
Old May 5, 2008 | 07:44 AM
Dang.. what a smooth and linear power delivery. That's just beautiful...
Old May 5, 2008 | 07:52 AM
ls1290's Avatar
Dumb Ass Vette Moderator
That is nice Bob. That is with a F1R right? How do you think a 235/245//598/608/115 cam would compare?
Keith
Old May 5, 2008 | 09:25 AM
sounds great and vary impresive numbers. that cam is my number 1 choice for now.
Old May 5, 2008 | 10:10 AM
what clutch do you recommend on that setup in a t/a
Old May 5, 2008 | 05:04 PM
Jake@EPP's Avatar
Keith
Something like that, possibly a hair more lift and put her on a 114.
As for clutch, if your around 800hp and beating on it, grab a spec 5 or a twin disc setup (preferably a mccloud or a spec).
Old May 5, 2008 | 06:32 PM
i was looking at a tex exo twin. do you have any complaints about that clutch?
Old May 5, 2008 | 06:39 PM
Jake@EPP's Avatar
Yes, i do not like it. I had one weld together and the second one was noisy as can be. There has been a large amount of people blowing through them with low amounts of hp.
We have had great results with the spec line of clutches, not so much chatterey or loud, just a firm pedal.
Old May 5, 2008 | 06:50 PM
cool thanks and one last question what size injectors did you use on the cts v?
