Pinning the crank with a double roller, not possible?
Well I am in the prosses of installing a pin kit for my 408 and I need to pin the crank (unfortunatly the shop I had build it did not put the keyway that I asked for). I purchased the ati kit which drills vertically into the crank, problem is I am running a double roller timming chain and it wont allow the sleeve to go on far enough on the crank snout. Will I have to remove the double roller and install the single to get this done or are there some other suggestions?
Thanks
Thanks
Thanks
Thanks
You don't want to pin it like that anyway, it will break. Pin it with your ati damper installed. Drill where the ati has a slot. The pin will slide straight in, half in the crank half in the slot on the ati. Then the crank bolt holds the pin in. Best way to do it imho.
