Blower Cam Decision, cam options listed
Old Aug 6, 2003 | 02:56 PM
MelloYellow's Avatar
Default Blower Cam Decision, cam options listed
I'm choosing a new Blower Cam and am looking for opinions!
So far my 4 choices are:
1) 218/224 563/568 114LSA 110CL Comp XE
2) 212/216 580/580 114LSA 110CL Lunati
3) 216/224 558/560 114LSA 110CL Lunati
4) 224/230 560/544 113LSA 109CL Lunati
I'm leaning towards #1.
If you like other grinds not listed, plz note & comment on overlap of your recc cam.
If you like #4, plz comment on the overlap.
Thx!
Old Aug 6, 2003 | 03:21 PM
Packy's Avatar
Default Re: Blower Cam Decision, cam options listed
I am going with your number #1 choice as well for my Forged 347. Mine is being built right now as well. Hopefully it will be on the road by Labor day weekend!!!
Old Aug 6, 2003 | 03:24 PM
Cool. Ya, looks like a stock Comp grind #54-000-11 3712/3715 HR 114.
I know the above cams are similar, except #4.
#2 sounds like a bit of stress on the valvetrain.
* Edited #4 for 113LSA.
Old Aug 6, 2003 | 03:32 PM
xtream1's Avatar
Mello, the cam should be matched with the heads that you're using. Noticing that you're using stock LS1 heads, I presume that peak flow is about 525 and max stock spring lift also comes into play. Personaly I chose a Comp grind about 518/528 with a lift of 525/537 at 114. IMHO you're forcing the air in but it's going to need more time to get out and I also wasn't interested in overstressing the springs unnecessarily.
Old Aug 6, 2003 | 04:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How high do you want to buzz the motor?
Old Aug 6, 2003 | 04:33 PM
02BlackWS6's Avatar
I called Comp about the 218/224 cam as well. But I'm looking to have it cut on a 115lsa or maybe a 116lsa.
Old Aug 6, 2003 | 05:54 PM
I'd like to shift around 6500, rev lim around 6700 or so.
Even if peak flow is around .530 stock, you want to get them open and stay up there .530+ longer, not just peak at .530 for a sec, eh? Even if the heads max at .530, having a peak lift around .560 would give you more time at max .530+ flow, right?
Old Aug 6, 2003 | 06:19 PM
NoGo's Avatar
Another vote for #1.
Old Aug 6, 2003 | 10:38 PM
ChrisB's Avatar
Do you want to max out the s-trim, and if not, what are your hp goals? What pulleys (ratio) do you currently have on it?
Old Aug 6, 2003 | 11:02 PM
Crunch's Avatar
I'm using one very similar to your #1 Choice. That cam should peak at around 6500RPMs, which is exactly where I shift. It looks like you'll be shifting there too.
That cam sounds VERY wicked with the SLP Loudmouth and the blower by the way.
Old Aug 7, 2003 | 12:32 AM
Thanks everyone!
re: the S-Trim and Blower RPM, I'm not sure where it maxes out, but I'm not exceeding any impeller specs. The C5 kits run on a secondary cog system. The LS6 kit has a 34 Tooth Cog, the LS1 has a 30 Tooth Cog and there is an optional 28 Tooth Cog direct from Vortech.
The 28 Tooth should make around 10# on a stock LS1 Motor. I'll run the 28 Cog and past that will run Nitrous if I want more. I don't want to get into belt and pulley headaches past the 28 Cog. You have to start messing with the primary pulleys and could run into slippage. Check out the C5 bracketry setup and secondary cog system. It's very well thought out. Crossing fingers everything lines up well and no belt issues.
HP Goals are modest.
Cam, Long Tubes, S-Trim 10# kit, Air Filter, Ported TB, True Dual Exhaust, LS6 Intake.
Would like to see 575rwhp.
Many C5's are pushing higher than that at 10#.
50 Shot should add at least 75rwhp.
Anything 650+rwhp would be great.
Traction with 335/30-18 street tires will be the limiting factor.
Most likely only nitrous for the highway. Will get used to it. Only want a 5-6# bottle.
