what am i doing wrong?
Old May 16, 2008 | 10:01 PM
  #41
Schantin's Avatar
Originally Posted by Rickys S/C Z28
here we go
Ricky, something's causing the car to "hiccup" at 4900RPM. Most likely a Ve tuning value needs a slight adjustment in the 4800-5200 RPM boost cells. Also, how much timing you currently running? HP is about right, but you should be seeing the torque earlier...and more than 405. I'm running 20* timing WOT. Timing increase will help the torque.
Also noticed the HP is getting pretty wavy in the upper RPM range....even with a smoothing factor of 5 on the graph. Leads me to believe that there is a "surge" in the incoming airflow. Belt slip, probably. Also check to make sre there's no "air-blockers" from the intake to the throttle body, such as overlapped pipe connections against the "flow" of the incoming air.
Here's my graph as a comparison at 5PSI:
Don't worry Ricky....you'll get the car running faster
Old May 17, 2008 | 05:31 AM
  #42
EPP's Avatar
EPP
I feel that a set of 4.10 gears would totally transform your car, Ricky. For dragstrip use I'd also ditch the front sway bar and, as has been suggested, get a set of 90/10 shocks up front. Hal/QA1 double adjustable shocks were very well for this, as they can easily be redialed for normal street use.
KP is right, (as always) see if you can find someone who has the MM overdrive crank pulley, ASP also sells new ones. The stock ProCharger LS1 6 rib crank pulley is on the small side, making it hard to get much boost out of a P-1SC without excessive belt slippage, as it causes you to have to run a small pulley on the head unit. Bob
Old May 17, 2008 | 07:03 AM
  #43
Pinky93's Avatar
Ricky, this is good stuff for those of us learning about FI.....
Old May 17, 2008 | 04:57 PM
  #44
dcvingv6's Avatar
i will post up duno sheet when i get home but i dont think thats the problom as i have the DGs on there and there good to .650 lift, my cam is a .608
Ricky,
I also have the EPP FI cam, patriot gold dual springs, and lightly ported 317 heads. I was getting some valve float @ 6500.
My tuner said that i might have to shim the springs, or try the patriot extreme springs.
I was kind of surprised by that, that was actually the last thing that i thought i might have had an issue with. Again, in my case that was @ 6500, and i'm on a d1, but still something that i wouldn't over-rule completely.
FWIW
--Mike
Old May 17, 2008 | 11:18 PM
  #45
Rickys S/C Z28's Avatar
bob dont you think a set of 4.10 would be to much for the street? i was thinking about a set of 3.73s what do you think?
im right there with you man im learning as i go
Originally Posted by dcvingv6
Ricky,
FWIW
--Mike
wow good stuff there man ill take a look at it
Old May 17, 2008 | 11:20 PM
  #46
you right i have no idea what that is when i get back from school im going to take the car back and see if he can get a bit more aggressive with the tune and stay on the safe side as far as timing i think it a 18
Old May 18, 2008 | 02:16 AM
  #47
badass99ss's Avatar
Im runing 4:10's in my car. It is a love hate relationship, I love the quick acceleration but some times the short gears get on your nerves. I usually go first straight to fourth.
Troy
Old May 18, 2008 | 07:04 AM
  #48
my car is an A4, if i had a M6 it think i would love it
Old May 18, 2008 | 12:54 PM
  #49
badass99ss's Avatar
Sorry....my bad
Troy
Old May 23, 2008 | 06:39 PM
  #50
sorry guys iv not been on latey but im in school , not that it matter i broke my trans and have to send it back to hawaii
Old May 23, 2008 | 07:16 PM
  #51
pozesd99''s Avatar
why did you put 3.08 gears??? you want like a 3.73 or even a 4.10.. with centri superchargers, you get boost with rpm... they are belt driven, so as to why you would have put longer gears confuses me.. running 6 lbs on that set up should make run what you ran.. get a smaller pulley and get some gears...
Old May 23, 2008 | 10:40 PM
  #52
pozesd99''s Avatar
wow!!!!!
Old May 27, 2008 | 05:19 PM
  #53
i did not put the gears in my car there stock id like to put 3.73 in it but now i have to replace the trans
