Procharger on stock internals?
Number 7 has an issue because of the way our manifolds are designed (not designed for boost). The incoming boosted air dose not get dispersed well. Most of the air rushes into the manifold, and hits the back of the manifold, and gets directed to the #7 cylinder. So that cylinder runs leaner than others, and hence the reason its the first to go on a stock motor.
This is also why the tune is important, you need to make sure there is enough fuel going to it, while keeping in mind that the #7 will (because of the design) run leaner
My tuning is this friday, I'm on the stock bottom, I should be over 500HP to the wheels. Depending what it puts down, ill be putting a meth kit on it for added safety.
Thanks...
--Mike
Now, what about this scenario -- You say it's because of the way the intake manifold is designed? What if you throw a FAST 90mm on there?
Again I by no means an expert, and i think you will find that this is a highly debatable subject, and i don't have ANY experience with the FAST stuff. But about the best advice i can give, and what I personally am doing, is just saving for a forged bottom end. Especially if your looking for 500+.
And the added fact that boost is like a drug, you will eventually want more!!!
I know i was that way when i had my turbo buick, and i will be like that with this car! Hope this helps...
Thanks...
--Mike
(This is a comparison of the Head/cam N/A set up to the same with 7psi...made 580 here, but we had belt issues, a new bracket was installed, along with 60# injectors up from the 42s used here, and it made 613rwhp at the same boost setting)
Note the fat A/F, we left it even fatter with the 60's...
When my motor was in my car, they had it set at 12 pounds of boost, and did one dyno pull on a mustang, and it pulled 685rwhp.. lol- The motor would have not been worthy of lasting set at 12 pounds of boost.. went conservative- 7.9 pounds..
Make sure- of a good fuel source!!
I have had a couple issues with my torque arm (4 bolts that attach to the rearend.. (12 bolt moser) They were coming loose- so i fixed with some lock washers, and some red lock tite..
After that it's in your best interest to just break down and upgrade pistons/connecting rods..
thats with a stock 98 bottom end and some sorta blower cam at 8-9psi.... Don said it had more left in it but I wimped out.... would like it to last till winter.
And what blower cam
? (slowhawk) before I would let anyone else touch my computer
