Procharger on stock internals?
(slowhawk) before I would let anyone else touch my computer
Off topic for a second, but is your 9" a truetrac or locker? Also, what times did you run the quarter with those numbers??
On my first night at the track with the new setup I ran 11.8, seems the more power i get the harder it is to drive out of the hole....
And the driveability with that cam is pretty good? I know the specs on it are like a 238/242 or something like that..
Im starting to look for a forged short block simply cause this **** is addicting and I want more.....Boost that is!
Troy
Troy
Wow awesome! Yeah I will defiinitely be doing both also..
Oh well a 232/240 isn't as aggressive as I thought.. But yeah.. eventually forged is the way to go obviously, that way you won't have to worry about it..
Troy
I dyno tuned today 596 / 507 @ 6500 (dynojet)
11.5 max afr (forgot to ask what the timing was) but he said there was a ton left in it.
Mike @ New Era did the tune, drivability is great, idles like a cadillac, hell i can drive @ 45mph in 5th gear w/out a problem.
Altho the tune is great and very conservative, i knew and now definitely know that my stock bottom wont last...
Set up is as follows:
2001 factory ls6 block
D1 @ 8#
EPP FMIC
EPP FI cam
lightly ported 317 6.0 heads
Patriot gold dual valvesprings
manly pushrods
double roller timing chain
Pacesetter LT's
ORY
Borla catback w/ cutout (closed during tuning)
Textralia oz700
Nasty Fuel system
We'll see how long it last's!!!!
Thanks...
--Mike
D1 @ 8#
EPP FMIC
EPP FI cam
manly pushrods
Pacesetter LT's
ORY
Textralia oz700
Nasty Fuel system
Thanks...
--Mike
Great #'s! Our set-up is close to each other! My tuner said the same thing, there is a lot more power with this cam/set-up. What fuel system are you runing, you stated a Nasty fuel system. What does there fuel system include, pump, injectors, and fuel rails?
Troy
Racetronix 340L single intank pump
Racetronix hotwire kit for pump
-6ss feed and return lines
magnafuel fuel filter
nasty performance billet fuel rails
magnafuel AFPR w/ boost reference (we are not using the boost reference)
mototron 60# injectors
No problems with fuel at all!!!
Thanks...
--Mike
Thanks...
--Mike
I might have to give them a call. I have a Walbro 255, Hot wire kit, and 60# injectors. I was going lean at about 5200.
Thanks
Troy
When i have my motor forged, i will probably go with a 2nd 340 intank pump (like his stage 3 kit) on a hobbs switch.
Good luck!
Thanks...
--Mike
Blower kit installed around 1200 miles. Car now has 10,300 (yeah, garage queen). Very safe/conservative tune and have had no problems with the motor. About 12 passes at the track and probably ~20 street races (roll), so the car gets leaned on very infrequently when you figure it's nearly 6 years old.
I got pulled by a Speed Freaks turbo'd M3 last weekend.
He claims 620 to the wheels, so I guess I shouldn't feel too bad. However, my fingers keep starting to dial EPP to order up that 8 rib conversion and larger intercoolers. I have stopped them in time before the call went through, but one of these days... EDIT: M-Ten, it's still stock rev limiter. 6200 I believe. Stock springs and pushrods, so no plans to raise it.
..Seems like it's pretty durable as long as you keep a real conservative tune..
My tuner said it could probably go up to 7kish
I do have upgraded springs.
Thanks...
--Mike
Thanks...
--Mike
Maybe even throw a fast 90/90 on if I can be patient and save the extra money for it lol
