Xylene Plus Mystery Oil in Gas?
Just wanted your guys opinions on this. I just started testing with mixing xylene to 91 octane gas. Im using a 20% xylene mix (should bring it to around 100oct, havent done the math yet). The car (2002 C5) has 11.3:1 comp and it seemed to like it. The weather here has been hot and I have some races coming up so, I want to reduce knock and get better combustion in the hot weather. Here in SoCal it can get pretty humid, which kills good combustion, so I hope the high vaporization rate of xylene will help. I know a lot of FI and turbo guys use this stuff. Is 20% good (8gal. gas to 2gal of xylene)? Also, some guys I heard use that marvel mystery oil in the mix too, to help protect o-rings and such. If so, how much mystery oil should I use per 10gal? Thnx for any input.
The MMO is used as a top end lube. 1-2oz. per 10 gallons is the normally cited amount. I would start with 1.
Do you have knock with pump gas? If not, higher octane gas has no payoff for you. Octane is merely a number indicating resistance to detonation, not power potential.
Jim
Jim
I know what octane means but if you have no knock and more complete combustion then, yes, it will give you more power. There are many dynos that show how race gas can give up to 10hp alone on a high comp motor. Anyway, I just want to reduce any knock caused by high temp conditions and incomplete combustion due to humidity(xylene helps with a high evap rate).
I used to have a turbo GTi running 30psi on a fairly small turbo, the IAT and knock retard was increadable (even on 94 octane). I ran a coupple gallons of Toluene (similar to xylene) one day at the track and it definitely helped (picked up a coupple 10ths).
However it was less cost effective than race gas after I did the math. So I stopped useing it.
Higher octane fuel will have a slower burn rate. If you just tune some timing out you'll pick up more than 10 rwhp IMO
Doug
If you pull timing with high octane fuel on an NA setup, you will end up with an incomplete burn, expensive exhaust gases and less torque.
Jim
Doug
Its good stuff to bump the octane up. I used it in my Turbo buick all the time when turning the boost up. If you are on the threshold of detination, then it will help for sure. I liked it so much I bought a 55 gallon drum of it from the local chemical supply company, was MUCH cheaper that way. I think I only payed like 125 bucks a few years ago for the drum, vs 10 dollars a gallon at the Home Depot.
Chris
Chris
Chris
Chris
