just got my cam specs for my 402 ls2 turbo
Why? Ever ran one or seen one in person preform poorly?
And to the origional poster, your cam is WAY small for a 408. It is about the same as a STOCK C5 Z06 cam with a tad more lift. That's right.....a stock cam for a 346 cube N/A motor. I would reconsider how knowledgeable your builder is if he claims 7k+ rpms and 20lbs of boost with this baby cam.
So like I asked and you failed to mention:
Have you ever ran a reverse split? Do you know someone who has and wasn't impressed? Why don't you like them?
PS---Stenod and Camotion designed my cam so its not like I played some personal hunch I had.
....and one of my friends had great success with one.....and I've had several forward splits and single patters......MYSELF. I speak from real world experience.
I do agree on why would the shop tell you the wrong cam though?
well since we are on cams specs let me know if i got the right cam for my setup since its still on the engine stand. I hope its right. THanks Guys
370ci
91.5 turbo
cam specs:
hyd grind# Ls1 373R /372R HR115
intake lift .610
exhaust lift .605
intake duration 242@.050
exhaust duration 238@.050
lsa 115
370ci
91.5 turbo
cam specs:
intake lift .610
exhaust lift .605
lsa 115
LS1 3729R/3731R HR 115.0
Intake lift .605
Exhaust lift .610
Intake duration 238
Exhaust duration 242
LSA 115
#36
Shorty Director
Well damn!! If you guys think his cam is small then I assume mine is super small. Please tell me you guys think it is small due to the size turbo he is using and not due to him running a 402ci setup. My cam is much smaller and spec'd by Patrick G and it works fine. Power peaks at 6500rpm and holds to my 6900rpm redline.. Too big of a cam will kill lowend guys and girls..
#38
