LSX is ready to be dropped in tomorrow (PICS!)
#524
After I check all the fuses tonight, I'm pulling the pcm and taking it over to speed inc so they can check to make sure it's working. The only doubt I have about the pcm being the problem is, I wouldn't think I would have spark if it was shot? It will be good to know though because if it checks out then that's one more thing to narrow it down. The crank sensor will be next.
#529
I agree that I do not think that the belt would be a problem. And I also like the possibilites of the ignition relay, especially after the starter issue.... I will try to find the documents when my car we burnt down and see if they state if they replaced any fueses.
Have you been able to get the PCM checked yet
#530
Just a thought because your car sounds just like when we tried to fire my buddies car up after a cam swap.
#531
Hate to ask, but are you 100% sure your timing dots lined up? If your timing gear set has dots for advance/retard timing they can be confusing when lining them up (ask me how I know ).
#532
You checked all your fuses already? Do you happen to have a Haynes manual handy? The have electrical diagrams in the back that can help trace wires. Electrical problems are a pain. There are hundreds of places to check. Once you get your PCM checked, I think you'll be able to narrow down the issue much faster.
#535
Thanks man, me too.
I have spark. A lot of suggestions I'm getting wouldn't give me spark. How would I go about checking relays anyway? Or do I have to swap them? I might as well check them while I'm doing the fuses.
I'm going to check the grounds behind the head too, to make sure one of those didn't break maybe?
#536
I hope I find a bad fuse tonight but no, haven't had a chance to check them yet.
Thanks man, me too.
Thanks man, me too.
#538
Checked the fuses in the engine bay, they are all good. I also felt behind the drivers side head and the three gounds back there all feel good. I did find one tiny ground wire that's under the shifter console that didn't get bolted back on. I can see it with a flash lite but I can't reach it without removing the console. I doubt it has anything to do with starting but who knows, grounds are wierd. I'll have to get back under there and bolt it down. I did get the computer out so that will get checked also. Once I take care of the little ground and get the pcm back, I'll try to start it again.
