LSX is ready to be dropped in tomorrow (PICS!)
Old 09-12-2008, 02:18 PM
  #621
2000_SS's Avatar
a compression guage is good to have for sure. you may as well get a new MAP on your way home too. that little diaphragm inside of it is SUPER sensitive, much like the element on a MAF sensor. if your intake did fill up with liquid, sludge, and/or metal debris...there is a 99.9% certainty your MAP is fucked...and being a SD motor, that's a pretty critical sensor.
Old 09-12-2008, 03:52 PM
  #622
sevanseriesta's Avatar
Yes it would!
Old 09-12-2008, 04:28 PM
  #623
Twotonefreak's Avatar
I'm betting also that its not getting fire. Sounds just like mine did when cranking it over with the coils unplugged. Good luck with it man, I know how frustrating it can be.
Old 09-12-2008, 04:40 PM
  #624
DanZ28's Avatar
I'm on board with Fier67 on this one. It sounds alot like a friends vehicle that had a low impedence injector box wired up to the wrong injectors. Double check that crank ring and make sure it's on right or that it's even the right one. Also be careful how much fuel you dump in the cylinders or your gonna get cylinder wash and you rings will never seal.
Old 09-12-2008, 05:56 PM
  #625
rufretic's Avatar
The compression test was interesting to say the least. Unless I was doing it wrong, I got a whole 0 lbs of pressure! I put it in the spark plug hole, unplugged the coils, took out the injectors fuses and cranked it over for about 3-5 seconds and got nothing and then tried another 3-5 seconds and still nothing.
I'm going to get a pushrod length checker tomorrow. Is it even possible to have a 7.4 pushrod be that much too long to cause 0 pressure? I took the coils and valve covers off after that. I also took off the two rockers on the cylinder I'm pressure checking. It's real hard to tell by the eye but it looked like the valves may have came up a touch when I loosened the rocker arm. I'll take a pic to show.
Now can I do a pressure check with the rocker arms off to make sure the valves are sealing? It seems like it wouldn't work because there is no where for the air to move so unless that piston is all the way down, it wouldn't be an acurate reading?
On a good note, I got my blower belt in and it's huge and fits great. I'm going to install the tensioner and then post some pics. At least my cog set-up came out awesome, it sould be solid. Now if I only didn't **** up the engine side of it I would be ready for some dyno tuning next week.
Old 09-12-2008, 06:01 PM
  #626
rufretic's Avatar
How much does it take to do that? I'm getting fuel in the cylinders for sure, it smells like gas in my garage. I cranked it for mayby 2-5 second intervals around 15-20 times, a few of those with no fuel because I took out the fuses but most of the times had fuel. If I fucked the engine I'm going to cry. Is there anything I can do now to avoid that, like maybe take out all the plugs to give it a little air to evaporate?
Old 09-12-2008, 06:15 PM
  #627
rufretic's Avatar
I'm wondering if maybe my engine builder cleaned up the deck on my block and either I forgot he mentioned it or he didn't mention it? That could make the stock length pushrods too long. Also, here's my cam specs: 246/250 .632/.635 on a 112+4 Not exactly mild.
Here's the pics, hard to tell from pictures but maybe someone with more experience can see more than me?
Old 09-12-2008, 07:39 PM
  #628
TS6
TS6's Avatar
Your pushrods have to be too long, even a completely fucked motor would show some compression.
Old 09-12-2008, 07:41 PM
  #629
What was changed that would be the reason the pushrods are too long!
Old 09-12-2008, 08:11 PM
  #630
rufretic's Avatar
I'm not sure, I thought the same length would be right but I guess a lot of little things can add up when your talking pushrod lengths. Here's what changed:
ls1 346 to lsx 402 = +.015 per dirty
mls gasket .05 I think to cometic .04 = -.01
232/234 .598/.598 112 cam to 246/250 .632/.635 on a 112+4 cam = ?
Stock lifters to cadilac lifter = ?
Stock rockers to harlan built stock rockers = ?
Same heads
Without knowing the ?s it's hard to say but it doesn't seem like I should need shorter pushrods unless that monster cam has a larger base circle or something. I can't remember if that's what it's called but a cam can make you need a different pushrod if I remember right. It's been a while since I did cam research but that's the only reason I can see.
How else could I get 0 compression other than too long of pushrods?
Old 09-12-2008, 08:16 PM
  #631
rufretic's Avatar
Well, whatever the reason, I'm going to make sure my pushrods are perfect now either way. Now I just need to figure out how to find the right length with the push rod checker. I researched it before and it seems like there is a lot of opinions on it, that's actually part of the reason I just went with stock length. Is there a correct way to do it or do I have to guess on who to listen to lol.
Old 09-12-2008, 08:45 PM
  #632
smokin91rs's Avatar
Default compression
do the compression test with the rockers off of a cylinder if you got compresson your pushrods are way to long and holding the valves open or your cam timing is way off
Old 09-12-2008, 09:58 PM
  #633
2000_SS's Avatar
pushrods gotta be too long.
Old 09-12-2008, 11:34 PM
  #634
c0ncEpT's Avatar
I believe I was the 1st one to mention that in this thread I feel some what accomplished
Old 09-13-2008, 02:52 AM
  #635
1dirtyZ's Avatar
was some one holding the guage and watching it while you were cranking?
Old 09-13-2008, 04:35 AM
  #636
DanZ28's Avatar
just check your pre-load and let us know what it is. The LSX deck is taller but I'm sure your machinest shaved it down some. Your base circle is probably smaller than stock. Now the caddy lifter i have no idea. Again, just make sure your pre-load is good. Whats the preload spec on the caddy lifters ?
Old 09-13-2008, 08:50 AM
  #637
rufretic's Avatar
Good call!
Old 09-13-2008, 08:52 AM
  #638
rufretic's Avatar
No, it sat high enough for me to watch it myself while I was cranking. The pin didn't move.
Old 09-13-2008, 09:14 AM
  #639
ninetres's Avatar
Which would call for longer pushrods then.....right? I believe I run 7.45 rods with my 640 lift cam.
Old 09-13-2008, 11:17 AM
  #640
Rickys S/C Z28's Avatar
man you went up a bit with the cam im going to say it the pushrods also
Quick Reply: LSX is ready to be dropped in tomorrow (PICS!)
