LSX is ready to be dropped in tomorrow (PICS!)
Old May 14, 2009 | 02:50 PM
  #1081
Jimmy P's Avatar
I would call one of the other torque converter companys and have them spec out a converter for your setup. I am not sure the Vig 4000 was ment to be used ina F2 car lol.
Old May 14, 2009 | 03:01 PM
  #1082
98turbls1's Avatar
I would call Marty at Neal Chance.
Old May 14, 2009 | 03:13 PM
  #1083
99Ls1fever's Avatar
Checked out your Fquick, very sexy Car man!!!
Old May 14, 2009 | 03:25 PM
  #1084
rufretic's Avatar
Yep, originally got quoted by him, just ran out of funds for the good stuff
Old May 14, 2009 | 03:35 PM
  #1085
98turbls1's Avatar
Unfortunately that's where you make your money... I hear ya. Having to part out some stuff myself. Getting a house and need all of the money that I can get. Good luck man.
Old May 14, 2009 | 03:48 PM
  #1086
98turbls1's Avatar
Thanks man, she's down right now awaiting a turbo.
Old May 14, 2009 | 10:02 PM
  #1087
Disturbed Bird's Avatar
subscribed
Old May 14, 2009 | 10:24 PM
  #1088
StrokerTA's Avatar
Coan converter for sure!
Old May 15, 2009 | 12:21 AM
  #1089
hawk584's Avatar
Old May 15, 2009 | 12:27 PM
  #1090
rufretic's Avatar
Well, things just got a little more interesting. I went to pick it up this morning and just checking over everything before I started her up I noticed one of the plugs was touching the header. It was fried real bad and Larry said he didn't see anyway it could be firing burnt that bad. I'm trying not to get my hopes up because I don't want to be too disappointed if it's the same but it's possible the 600rwhp it made was on only 7 cylinders. I changed the plug wire and have a little more touch up to do with the tensioner pulley but after I'm finished with that they are going to throw it back on the dyno just to see if that's why it was down on power. Still can't go max effort because the 80s are maxed but at least it will show the potential it has. The converter will still need to be changed either way but it would be nice to see it making a little more power. I'll update once we get it back on the dyno.
Old May 15, 2009 | 12:31 PM
  #1091
98turbls1's Avatar
Well isn't that a little friday happiness shining down on you. Good to hear man and that would be awesome if that was the problem. Keep us updated.
Old May 15, 2009 | 02:35 PM
  #1092
z28boy's Avatar
Speed inc will take care of you for sure, cant wait to see what this thing does.
Old May 15, 2009 | 04:27 PM
  #1093
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's some good news. I'd be careful with how hard you push that converter.
Old May 16, 2009 | 02:40 PM
  #1094
02SOMWS6's Avatar
bad *** car man
Old May 16, 2009 | 06:57 PM
  #1095
rufretic's Avatar
I fixed up the tensioner pulley so it can't come loose now. It should be back on the dyno Monday or Tuesday for one last pass to see if the power is there now that it's running on all 8 cylinders.
Old May 16, 2009 | 08:01 PM
  #1096
OWN3D BY MY PROF!
If your 80s are maxed out on 7 cylinders I don't see the purpose of going back to the dyno until you can put a larger injector in it. I'd also be very careful about ballooning that converter. It may be built with some sort of anti ballooning plate in it, but I'm sure it isn't up for the task of what you'll be putting it through. I would hate for you to run into something stupid like bearing issues because of a converter.
Old May 16, 2009 | 08:27 PM
  #1097
rufretic's Avatar
The purpose is just to prove what it's capable of because I'm most likely going to have to sell or part out and it's going to be real hard to sell if it doesn't make the power like it should. My tuner is very good and he isn't going max effort since we know it doesn't have the fuel but even if he can get it to make 750rwhp @ 6000rpms(which should be plenty safe for the 80s) it shows that the motor is good and it has a lot of potential. I may not be able to upgrade the fuel, heads and converter, ever. So I think one last pass just to see if the power is there is something I have to do.
The converter was made for racing, TH400 no lock-up. The guy I got it from had a 500rwhp N/A set-up that he was spraying with a 200 shot off the line. He said with the spray it was flashing to 4000rpm. So it may not be my ideal converter but it should be able to hold some power.
I do understand your concern though and trust me, with two years of time and a shitload of money, I'm scared shitless something bad might happen. I can't even get a good nights sleep but I don't really have much choice. If I planned to just park it back in my garage and sit on it till I could upgrade what needs upgrading, I wouldn't put it back on the dyno. Desperate times call for desperate measures. I'm going to try and video it so at least I have something to show for it once it's gone. So please wish me luck.
Old May 16, 2009 | 09:00 PM
  #1098
kp's Avatar
kp
Shame to see you have to sell it off after all that work. Honestly you will be better off parting it out if you need the need to extract the most cash out of it so I dont know if I would beat it up any more.
Old May 16, 2009 | 09:13 PM
  #1099
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Curious to see what you find on the dyno. Boy, if one plug wasn't firing I would think one bank would be pretty fat.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old May 16, 2009 | 09:20 PM
  #1100
rufretic's Avatar
True, but who's going to want to buy an engine that made 600rwhp with 26psi lol. It is only one more pull to see if the power is where it should be, 5 pulls or 6 pulls won't make a difference unless something bad was to happen and I think if it was going to break it would have done it on the first pull. Everything held good so I'm just hoping to show the potential of the engine, the blower set-up is already proven as far as I'm concerned, 26psi is awesome and all my bracket stuff didn't budge other than the tensioner pulley loosening and now I have a bolt holding it in place like the procharger j bracket has. The th400 isn't even being tested at this level because it was built for 1200rwhp. I guess the smartest thing to do would be just dyno the engine without the blower but after all that work I'd at least like to get the satisfaction of a nice dyno pull.
