LS2 403 D1SC Procharged 'street driver'.
According to some of the on-line calculators plugging in raceweight and 1/4 MPH it shows to be around 660-670 RWHP.
I ran this Yank PY3400 in my LS1 h/c and it is a dyno HP eater.
After adding the Transgo BPV-BOV the trans shift points were corrected. Still making 9# shifting at 6200 RPM now crossing the stripe at 6300 RPM. Car is working good. 60's were 1.44 and 1.45.
It is great to be able and get in it and go anywhere and idle quietly next to another car and be able to hold a conversation out the window. It makes for a good sleeper in street trim with the SS rims and ET Radials. Its very quiet through the cats and Magnaflow cat back and has very good street manners with a nice sound.
Already had my first victim, a 9 second Z06 with a turbo that couldn't hold a candle to my launch on the street with the Hoosiers QTPs. I had 3 cars on him at the hit. If I had to guess my car leaves just as hard on the street as it does at the track.
I got some video of the track I will work on getting on the 'puter. Wasn't the best this time.
I got a HOWE 2 core radiator which helped until about 90* outside, but anything other than that and it still got hot. I added a small Spal fan and wired it into the other. It's got to an all time high of 236* sitting still for 5 mins on a 100* day after being fully warmed up.
In repsonse to your other ? I run a Hoosier Quick Time Pro 27" x 11.5" on a 15" x 9.75" Bogart D10. Works very well with my converter and chassis.
im running a disc/carb on the 6.0 now, with a vette front acces setup, 8 rib conv.-looking to step it up a little with a stroker and man shift 4l80e that i am building
great write up, wish i could see the vids, i have slow dial up, lol
In the process of upgrading the radiator to the ron davis unit and will be calling epp to get the 9" spal fan to hook up to the larger fan provided with the kit. Should be about two months before I get all of the stuff installed but will have to wait until the first hot spell here in NC to see if the changes worked.
I haven't driven the Camaro since October last year before I parked it for the winter after getting smoked by a Lingenfelter twin turbo Vette on the street. It was humbling, but I knew something wasn't right with the car, it felt soft. So after 5 months I am looking around under the hood and peak back near the radiator and notice the plenum is splt all the way across the bottom back. I have an idea how to fix it, but I think I will do a radiator too.
Need that A/C going.
Hope to see the Vette again in the spring!
EDIT: Just looked on their site, $577 for a drop in rad. for a Camaro (you'd have to check to make sure it's a 2 core).
Afco makes a good product as well but I have seen many positive write-ups on the Ron Davis products.
