Lowest 402 dyno #'s ever
Old Jun 4, 2008 | 06:37 PM
riach's Avatar
Default Lowest 402 dyno #'s ever
Haven't posted in a while, been working on the house nonstop. Had time to bring my car to the local dyno shop the other day. They had a dyno jet dyno and the numbers were 520HP @5500RPM 513LB/FT torque @5200RPM. Air fuel ratio was around 12-1. Intake temp 88degrees. Belt started slipping after 5500RPM and dropped very slightly and held around 11LB of boost all the way to 6500RPM. Do the numbers seem low to anyone else? I think at 5500RPM w/a 402 and D1 Procharger, I think I should still have more HP and torque then this.
Mods, to the best of my memory, are as listed:
- SLP ZL 402 Iron Short Block
- LQ4 Heads
- Comp cams valve train
- D1 SC Procharger
- Cooks 1 7/8" Headers
- Mack Exhaust
- FMIC
- 218/224 114LSA Blower Cam
- 8 Rib Set Up
- SDCE Tensioner
- Curry 9" Rear 410 Spool
- LS6 Intake Manifold
- 60LB Injecters
- Aeromotive 1000HP Fuel Pump
- Aeromotive FPR
Car was dynoed w/air filter off. I do need a new belt, but the numbers still seem low to me. Having trouble getting my scanned dyno results into my post, if anyone can give some tips on that then I can get it up.
Thanks, Rich
Old Jun 4, 2008 | 06:43 PM
ninetres's Avatar
ehhhh??? Auto tranny? W/ 4.10 gears and a 9"???? Still a little low for that much boost IMO.
Old Jun 4, 2008 | 06:52 PM
riach's Avatar
I knew I forgot something car is 98 t/a 6spd tranny spec stage 3 clutch. angry and tired tonight sorry. CRS. let me know what else I forgot. thanks again rich
Old Jun 4, 2008 | 07:00 PM
hellbents10's Avatar
LS1Tech Sponsor
hmmm, not very impressive.
Old Jun 4, 2008 | 07:36 PM
Black01M6SS's Avatar
Something seems wrong. Those numbers are way low IMO. Looks like a nice setup you have.
Old Jun 4, 2008 | 08:32 PM
OUTLAWZ RACING's Avatar
its a little lean 12:1 is not ideal. Should be around 11:3 11:6 to be safe allso belt slip is a factor. Oh just seen auto with a 9inch and spool that will eat it up allso. The best way to be safe is to fix the afr and runnit at the track.
Old Jun 4, 2008 | 09:04 PM
LASTLS1's Avatar
6 Second Club Moderator
- LQ4 Heads
- D1 SC Procharger
- Mack Exhaust
- FMIC
- 8 Rib Set Up
- SDCE Tensioner
- 60LB Injecters
- Aeromotive FPR
Thanks, Rich
You have a problem somewhere? I made more rwhp with my 408 hyd motor through a turbo 400 n/a.
Old Jun 4, 2008 | 09:45 PM
Darren P's Avatar
I made 650 with 8 pounds of boost on my 403 through a 4L80E
Old Jun 4, 2008 | 11:04 PM
CAMAROZ28AQUINO's Avatar
somethings wrong for sure man....i seen a guy a couple weeks ago with a stock c5 Z06 with heads and orx, stock catback with a D1 made 594rwp! The guy who tuned that car has an 02 C5 Z06 with a 408, procharged and hes at 950...he goes by the name of EB02Z06...he should be able to help you
Old Jun 4, 2008 | 11:20 PM
crashinaz's Avatar
TINY cam for a 402. Sell it to someone with a stock bottom end motor running low boost.
Old Jun 5, 2008 | 04:42 AM
EPP's Avatar
EPP
Do you know if the camshaft was properly degreed in? Bob
Old Jun 5, 2008 | 07:34 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I am tuning one of two things:
1) The tune is way, way off.
2) Low compression in 1 or more cylinders.
The 12:1 A/F is not too bad, but a bit lower is more optimal. Since you are seeing 11 psi of boost, you most likely do not have a boost leak from the intake and back. I would do a leak down test on the cylinders to make sure you do not have any bad rings. How was the motor broken in? Are you seeing any knock or misfires?
Keith
Old Jun 5, 2008 | 09:50 AM
2001WS6Vert's Avatar
A few years back when I had a T-trim a Ford shop with a dyno jet got me 440 rwhp. I knew something was wrong so I went to another shop and got 575 rwhp, no changes to the car. ?????
Old Jun 5, 2008 | 10:13 AM
bluebeast's Avatar
how does it feel on the street? is it atleast peppy and strong feeling or does it feel stronger that 520rwhp?
Old Jun 5, 2008 | 10:46 AM
06 Blue Goat's Avatar
Those #'s are not even close tuning is a big factor how much timing is in it?
Old Jun 5, 2008 | 12:35 PM
pozesd99''s Avatar
dude that cam is sooo tiny.... it like smaller than a stock z06 cam... im guessing that together with the tuner would be your problem
Old Jun 5, 2008 | 05:53 PM
riach's Avatar
Thanks for all the great replies.
As far as the tune goes, it was about 19degrees of timing. On the street the car feels strong, there are no driveability issues.
If the cam was degreed in wrong, would the car have some sort of idle issues or driveability issues?
And if there were low compression in 1 or 2 cylanders wouldn't I notice this driving the car? As far as I can tell, the car drives strong, doesn't stumble, but the tune could definitely be an issue. The car did blow a header gasket when on the dyno, maybe my high flow cat is too restrictive for the car.
The SLP block is a new block w/less then 4000miles on it, over 3000 over which were on a break in tune w/very little timing, so I'm not really sure where to go from here.
I'm still having trouble getting my scanned dyno results on here, if anyone can give me some tips on that then I can get it on here.
Thank you all again, Rich
Old Jun 5, 2008 | 06:11 PM
EPP's Avatar
EPP
Like I mentioned the other day, Rich, you could indeed have a clogged cat. We've had it happen and it certainly kills the power level. Bob
Old Jun 6, 2008 | 07:14 AM
ls1290's Avatar
Hey Rich,
I have sent you a PM on this
Keith
