Should I have keyed the crank?
Old Aug 12, 2003 | 11:05 PM
Crunch's Avatar
Default Should I have keyed the crank?
I did not read up on keying the crank prior to my engine rebuild. The machine shop did not mention anything about it either. Its only now that I'm finding out that perhaps I should have had this done.
My questions are:
Is it too late to key the crank? (The motor and blower are already back in the car).
Can this be done without removing and pulling apart the motor again (i.e. another $1500+ labor )
What is the worst thing that could happen if I don't get this done?
Am I making enough power where this would make a difference?
Thanks.
Randy.
Old Aug 12, 2003 | 11:18 PM
whitt1's Avatar
Default Re: Should I have keyed the crank?
I pinned mine with the motor in my truck.I used a kit I got from Magnacharger,it consisted of a drill guide,a hardened drill,a reamer and 2 hardened dowel pins.It's the same setup Magnacharger uses with their C5 kit.
Old Aug 12, 2003 | 11:24 PM
Crunch's Avatar
What about this "ATI" kit I heard of. Can this be installed without taking apart the motor?
Old Aug 13, 2003 | 01:06 AM
Mike00FRC's Avatar
I have the ATI crank pinning kit. It can't be more than a couple dollars for it. Its only a guide, pin, and a bolt to hold the guide in place.
The crank can be pinned with the engine in the car. All you do is remove the crank bolt and install the guide with supplied bolt on to the crank pulley, drill, pin and then install a new crank bolt.
On a C5 we have to move the rack to access the crank bolt, but on the f-bodys, I think you have access without having to move anything.
It should cost you maybe $25 if you do it yourself... but I'm not positive of the price of the kit as it was included in my total package.
Old Aug 13, 2003 | 06:52 AM
2001WS6Vert's Avatar
ATI Performance Products, 1-800-284-3433. Part #918993, $121.93 + S & H.
Old Aug 13, 2003 | 11:53 AM
Crunch's Avatar
Thanks for your help!!
Just the info I needed.
Old Aug 13, 2003 | 11:58 AM
Mike00FRC's Avatar
Damn, didn't think the kit was that much... there is nothing to it.
Old Aug 13, 2003 | 01:09 PM
Crunch's Avatar
Better than removing the engine ($1000+).
Old Aug 18, 2003 | 03:59 AM
blue98coupe's Avatar
I have the kit I used on my magnacharger if you want to borrow it .You will need to order the hardened pins for it .Shoot me an e-mail tlauriano@surewest.net
Old Aug 18, 2003 | 07:08 AM
Crunch's Avatar
Already got it from ATI. No big deal.
Thanks anyway.
