intercooler fitting???
Old Jun 5, 2008 | 08:30 PM
theblur98ss's Avatar
I cut the front out of my bumper support and put the IC in there. Bolted it down from the top. I can't see it working very well if it's in front of the support like pictured above. There is no where for the air to go through it.
Old Jun 5, 2008 | 08:44 PM
presto_z's Avatar
Originally Posted by HTCooP34
one last question did anyone have to do anything with the alternator??
yes it has to be relocated
alot of people use smokinhawk's relocation bracket, send him a pm https://ls1tech.com/forums/member.php?u=2311
Old Jun 6, 2008 | 06:08 AM
CamaroSS19's Avatar
Originally Posted by presto_z
most people run an Air to Air intercooler like mine pictured here
and this is how i mounted it
i used 2" square tubing, then came off of it with 2 pieces or 3/4" square tubing.. this also allows a little bit of adjustment from left to right so you can center everything up perfectly.. im going to weld it all up
mount
Is that the ebay intercooler and what size is it my man
Old Jun 6, 2008 | 06:57 AM
presto_z's Avatar
yes it is..
Dimensions:
Core Size 24" X 12" X 3"
Overall Size 31" x 12" x 3"
3" Inlet and outlet
3" Thick Core
