intercooler fitting???
Old Jun 5, 2008 | 06:55 PM
HTCooP34's Avatar
Default intercooler fitting???
How hard is it to install a intercooler in a ls1 camaro?? what modifications have to be done?? any help appreciated. Thanx
Old Jun 5, 2008 | 07:09 PM
presto_z's Avatar
its pretty simple but more info is needed
are you planning on a basic 1 inlet/outlet Air to Air intercooler?? are you looking for an Air to Water intercooler??
Old Jun 5, 2008 | 07:15 PM
presto_z's Avatar
most people run an Air to Air intercooler like mine pictured here
and this is how i mounted it
i used 2" square tubing, then came off of it with 2 pieces or 3/4" square tubing.. this also allows a little bit of adjustment from left to right so you can center everything up perfectly.. im going to weld it all up
mount
mount from the front
running the piping is a little tight, but once you relocate a few things it frees up some more room
Old Jun 5, 2008 | 07:19 PM
HTCooP34's Avatar
did you have to remove anything. was there room to just stick it in there?
Old Jun 5, 2008 | 07:22 PM
HTCooP34's Avatar
which would be easier or more affective. air to air or air to water?
Old Jun 5, 2008 | 07:24 PM
presto_z's Avatar
for the intercooler i had to take out the Styrofoam behind the front bumper and for the piping i had to relocate the horns and trim some of the plastic off of the fuse box..
Old Jun 5, 2008 | 07:26 PM
HTCooP34's Avatar
but that wasnt too hard was it?
Old Jun 5, 2008 | 07:27 PM
presto_z's Avatar
air to water is more effective but also more expensive. for a Daily driver Street/Strip car i would stick with an A2A setup
Old Jun 5, 2008 | 07:29 PM
HTCooP34's Avatar
ok thanx mine is going to be my DD so i guess i will go A2A thanx to everyone who helped
Old Jun 5, 2008 | 07:30 PM
presto_z's Avatar
no, not at all.. are you planning on installing the turbo setup yourself?? you may want to read through some threads and see what work has to be done
Old Jun 5, 2008 | 07:32 PM
RAGENZ28's Avatar
A2A with meth injection for added safety under full boost conditions would be what I would run for a daily driver.
Old Jun 5, 2008 | 07:38 PM
HTCooP34's Avatar
im not going to be going over 8 or 9 pounds...???
Old Jun 5, 2008 | 07:39 PM
presto_z's Avatar
to the Original Poster im not sure how much experience you have with forced induction, but you should definitely read these
https://ls1tech.com/forums/forced-induction/208864-turbo-faq.html
https://ls1tech.com/forums/forced-induction/567592-real-price-forced-induction.html
HTCooP34's Avatar
yeah me and a couple of buddies are doing it one weekend. i have checked threads and seen what people have done. im going with the ebay "wonder kit" and getting a different turbo, wastegate, and bov of course
Old Jun 5, 2008 | 07:42 PM
presto_z's Avatar
on a stock bottom end most people run 6-8, going over 8 is asking for trouble.
Old Jun 5, 2008 | 07:45 PM
HTCooP34's Avatar
ok i will definately consider that thanx for the heads up
Old Jun 5, 2008 | 07:47 PM
presto_z's Avatar
i have the same kit. keep an eye on these threads
https://ls1tech.com/forums/forced-induction/746837-project-turbo_z.html
https://ls1tech.com/forums/forced-induction/869152-ebay-turbo-kit-install-whom-need-help-wana-see.html
https://ls1tech.com/forums/forced-induction/923538-well-i-clicked-commit-buy-ebay-turbo.html
i started doing the install and realized there is not alot of room to fit everything. while a few people have kept the radiator in its stock place i decided to turn mine up vertical to give me some more room..
here is some info on that
https://ls1tech.com/forums/showthrea...light=radiator
the ebay kit was cloned off of the PTK kit
Old Jun 5, 2008 | 07:49 PM
presto_z's Avatar
there is also alot of good info in this build thread posted by FROST
https://ls1tech.com/forums/forced-induction/398956-beginning-something.html
Old Jun 5, 2008 | 07:54 PM
HTCooP34's Avatar
thanx for all the help and references.
Old Jun 5, 2008 | 08:18 PM
HTCooP34's Avatar
one last question did anyone have to do anything with the alternator??
