347 or 383 for FI and stock block
My car is going to be mostly street use and will see the track a few times a year. I plan on running my boost to at least over 10 PS1 if possible. Current mods are full bolt ons and d1sc.
What are your guys opinions on the matter.
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Also less boost even on a forged motor is going to be less stressful to it and make sure octane isn’t an issue as we have a local guy with a twin turbo 402 corvette that I believe has a high 9 to 1 very close to 10 to 1 compression ration and he still had to run meth because 91 just wasn’t enough. So going bigger doesn’t always work especially if your compression isn’t low enough to accommodate your local octane. I plan to go with a flat 9 to 1 compression or maybe even 8.9 to 1 in hopes to use the larger cubes and boost to work with the 91 octane and still make my power goals without the meth.
Either way you won’t go wrong but more cubes are normally a good thing for making more power. Although I don’t know what kit you are running so turbo sizing if you are going to be running turbos has some to do with the size of motor you want. I am going to be running a stage 1 APS kit and I felt 383 was a good in between as some feel 402 is too big and I don’t want to get a new block that is heavier so 370 iron was out and a LS2 is just an added cost that I didn’t want either as I wanted to use my stock block to, so that is when I decided that if APS says a 6.0 liter is the perfect size and 402 is too big even though many are running 402’s. A 383 would be just the perfect balance for me in bigger cubes and cost. Don’t know for sure so I guess I will just have to find out. Food for thought and I hope this helps some but in the end it is money and what you want. I now have to pay off my wedding so either my cars engine will have to be put off for 6 more months to a year or I may just go with pistons and rods if I can afford that even.
Good Luck
Travis
Lets say you have a 550rwhp 346 and a 550rwhp 383, both Procharged. Would there be a noticeable difference in SOTP fun factor driving around the street? What about track times?
Is the increase in cost to go 383 justified, especially when there are alot of 346's putting down some stout numbers, both at the track and dyno?
Gary
Gary
BTW thanks to everyone for you input so far.
Ive run my best times on a 382, stock LS6 block. Ive been using this same block, for about 3 years now, since I first fitted an LS motor to my car. Its been built, and rebuilt in various guises, from 346, 382, back to 346, and now 383, with varying pistons, heads, cam etc.
Its now a 383, and holding up fine so far.
my only complaint, is that the ****** still hasnt given me a 9 !!!!!
It has to stop somewhere. a 402 can make 800 RWHP and a 346 can make 800 RWHp. Go 346, make a but load of power and ge descent gas mileage. Dont go too low in compression. 10:1 will be fine. Great throttle response and driveability out of boost. There is no reason to run a super low compression and boost to the moon. Run higher compression and less boost and still make the same power. A good boosted engine starts with a good N/A motor.
http://www.exoticperformanceplus.com...html?item=1109
This 346 makes 740 rwhp through stock cats.
http://www.exoticperformanceplus.com...Car.php?car=40
The 383 would indeed give you more torque, it is a tough call.
Here is our price for bringing a car in, removing the engine and rebuilding it, then reinstalling the engine and tuning it in. http://www.exoticperformanceplus.com...php?service=83 Bob
Only kidding will more than likely be spending more soon.
Thanks for everyone else that has replied as well.
