Rear Mount double wrapping, Bad Idea
Old Jun 16, 2008 | 07:00 PM
TransAmcoupe98's Avatar
Default Rear Mount double wrapping, Bad Idea
I was skimming through alot of old threads on rear mounts and wrapping pipes. Alot of people seem to think the double wrapping the pipes will help insulate better. I actually emailed the company ThermoTec and asked about double wrapping pipes on a rear mount. They weren't really familiar with what a rear mount was but I said the main objective was keeping heat in. ThermoTec replied that double wrapping would not help keep heat in any better than a single layer of 1/4'' overlapping would and in fact, as soon as water is introduced to the wrapp that the double layer would trap in moisture and would not hold in heat as well as a single layer and the pipes would fatigue MUCH quicker. Anyways, just some food for thought for not only rear mount guys, but anyone who double wraps their pipes period. Stick with 1/4'' overlapping strips.
Old Jun 16, 2008 | 09:18 PM
engineermike's Avatar
I respectfully disagree. Well. . . at least on the insulation part of it. I do agree that it will shorten the life of the exhaust piping.
Old Jun 16, 2008 | 09:57 PM
I thought that it would help insulate better too but I read on the actual product to not double wrap so I emailed them and thats what I got back from a rep.
Old Jun 18, 2008 | 01:59 PM
DeltaT's Avatar
As soon as you overlap, you have a double layer of wrap anyways, so that makes no sense. I did a layer of aluminum-back ceramic batting on mine, making sure the seam on the wrap was oriented stright down for water drain(I don't drive this car in the rain anyway) and then did wrap on top of it. It's lasted for 3.5 years now, and when I removed part of the wrap to work on the exhaust, the pipe was fine.
Jim
Old Jun 18, 2008 | 06:18 PM
OUTLAWZ RACING's Avatar
Jim
Where did u get it?
Old Jun 19, 2008 | 12:50 AM
DeltaT's Avatar
Longacre Racing
Here's the ceramic batting on first:
And the black wrap afterwards:
http://home.mindspring.com/~jim_fisk..._wrapped2a.jpg
Jim
Old Jun 19, 2008 | 01:55 AM
chuntington101's Avatar
Jim did you use the silicon spray coating?? I heard this is supposed to eliminate the water problem??
Chris.
Old Jun 19, 2008 | 11:02 AM
DeltaT's Avatar
You can't stop water from getting up in any wrap, but most exhaust rot happens from the inside out due to water and acids produced as combustion byproducts. Who knows how long that spray-on silicon hangs around? I can't say.
Jim
Old Jun 20, 2008 | 01:56 AM
good point Jim!
what was the black wrap you put around yours after the heat wrap??
Chris.
