Boost Project..... Anything Else I Need To Add to The List?
Old Jun 17, 2008 | 04:39 PM
1fastz's Avatar
Default Boost Project..... Anything Else I Need To Add to The List?
Just wanting some input from fellow members to see if I am missing anything from my Project list. I already have some mods on the car as it stands, and i just added a Performabuilt Transmission too. Here is what I plan to get:
SPEED INC 370 Cubic Inch LQ9 Short Block
GM LQ9 Iron Block
Diamond Pistons (-13.7cc)
Diamond Plasma Moly Rings
Eagle H Beam Rods
Clevite Main / Rod Bearings
Machined and Assembled
Patriot LQ9 Stage 3 CNCd 72cc 2.08/1.60 Heads Assembled
EPP Custom Cam For Boost
Pro Magnum Hydraulic Roller Lifters
Crane LS1/LS6 1.8 Ratio Rocker Arm Kit
ATI ProCharger F Body Twin Inter-cooler D-1SC Kit From EPP (includes Fueling Items)
Boost gauge/ AEM Wide Band gauge.
Snow Performance Stage 2 Boost Cooler
Strange 12 bolt Rear End
90mm Street Warrior LS Intake
Nick Williams
90mm TB
Precision CNC machined
Old Jun 17, 2008 | 08:58 PM
98Z28MASS's Avatar
looks like you have a really nice list and build going there. Cant think of anything off the top of my head other than a good set of tires/wheels if its going to see a lot of track time. Good luck with the build and let us know how it turns out!
Old Jun 17, 2008 | 09:05 PM
52172's Avatar
sounds pretty mean. Been changing your mind a lot lately on your setup huh? ATI is proven can't go wrong.
Old Jun 17, 2008 | 09:45 PM
1fastz's Avatar
Yea, I was thinking about getting a whole other vehicle. Maybe a a c5 z06 but then i started to think about it. Im going to get a $25K Vette and then what? Go crazy all over again with a new setup and make that block forged with heads/cam and built tranny and all this other stuff. Its going to get expensive! So i decided to just build my car up. It might end up costing just as much as a c5 but its going to be alot faster than a stock z06 and be a much better build.
Old Jun 18, 2008 | 05:12 AM
EPP's Avatar
EPP
Question
GM LQ9 Iron Block
Eagle H Beam Rods
Nick Williams
90mm TB
How much boost are you looking to make? Bob
Old Jun 18, 2008 | 11:13 AM
1fastz's Avatar
Whatever the motor car handle safely. I was thinking in the 10-15psi range? Im not sure. Im new to the forced induction game. I know that 5-8 psi is the range of a stock block, so im sure the right forged setup can handle double, right?
Old Jun 18, 2008 | 11:58 AM
sevanseriesta's Avatar
you probably need to get a catch can
Old Jun 18, 2008 | 02:24 PM
98Z28MASS's Avatar
If fuel and tune is spot on a well built forged short block (like the one your looking at from Speed Inc) can certainly handle 10-15 psi. What are your goals for the car both Hp wise and track wise?
Old Jun 19, 2008 | 01:18 AM
1fastz's Avatar
I forgot about the catch can! Thanks!
Im looking for the setup to be in the 600+rwhp range. As far as times go, 10 seconds for sure.
Old Jun 19, 2008 | 04:53 AM
EPP's Avatar
EPP
If you keep the boost limited to 16 psi, a stock based head such as the Patriot's work quite well. For you 370 cubic inch engine I would use Patriot Stage 2 heads instead of the Stage 3 heads. The Stage 3 heads on a 370 will typically lose too much bottom end power.
Here is a 346 cid with Patriot Stage 2 heads that is making 740 rwhp with a very mild cam, this is with shorty headers and factory cats to boot!
http://www.exoticperformanceplus.com...Car.php?car=40 Bob
