Cam too big for a blower motor???
I have to decide on final compression ratio
I also have to decide if my current cam is too large..
It is 605/238, 610/242, 115 LSA, installed at 111.5 CL
Any thoughts on this cam , and compression ratio..
I will be starting at 8psi with plans to go to 12-15 afterwards..
TIA
TIA
As for compression ratio, I wouldn't do anything over 9.5:1 Just my opinion though... hope I helped! Good luck with everything.
My .03 cents
99TA..7.2@95NA
85GT..331/106mm turbo in the works
My .03 cents
99TA..7.2@95NA
If you build the motor to spin high RPM's and have plenty of stall or will launch at high RPMs on an M6, the cam may not be too big... particularly with the amount of torque the big-cube motor will give you. With the torque it could have, who cares if the cam is big... as long as the motor can handle high RPM's.
I agree with those who ask for more info. Too much you left unsaid.
Also, you may need a bigger blower than a D-1SC or equivalent to take advantage of the RPM range. And MAN are you going to need some fuel! A Turbo may be better for you, as well.
